Discuss
Starter Switch
 in
Dryer Repair
When I try to turn on the dryer with the starter switch (turns to the right, then back) it just
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Starter Switch
  #1 (permalink)
Old 07-22-2009, 09:07 AM
Junior Member
bbatey is on a distinguished road
Red face Starter Switch
Brand: GE   Age: 5 - 10 years
When I try to turn on the dryer with the starter switch (turns to the right, then back) it just humms. I took the motor plate off and the drum turns OK, not sure about the motor. Could this just be the starter switch?
Ads By Google
  #2 (permalink)
Old 07-23-2009, 05:26 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
On the GE's it is probably going to be the motor. Try to manually get the dryer to turn by having a friend push the start switch while you push in the door switch and manually turn the drum. BE CAREFUL!!! If it starts, you are going to need a new motor.
If you want more info and advice please post the full model number
__________________
  #3 (permalink)
Old 07-24-2009, 07:55 AM
Junior Member
Default GE Dryer
Thanks for your reply. To my dispay, I thought it might be the starter switch and I removed it, now I cannot put it back because two little metal bars fell out and I don't know how to put them back. If I manage to get them back in, I will try your method.
Bevelry Batey
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Starter tombat Refrigerator & Freezer Repair 10 01-18-2012 03:26 PM
3-1 Universal Starter Relay tkwock Refrigerator & Freezer Repair 11 10-14-2010 02:33 AM
Starter - TSD beckbean Refrigerator & Freezer Repair 0 05-27-2009 07:24 PM
replaced starter freezer stopped again flip2964 Refrigerator & Freezer Repair 3 12-09-2007 07:01 AM
Starter relay tv guy Refrigerator & Freezer Repair 0 08-10-2007 01:08 PM
