Discuss
Maytag Admiral Dryer Dead
 in
Dryer Repair
Amiral Dryer Model ADE7000AYW s/n#15150625GC is dead. I changed the door switch, thermostat control,and the T-stat hi limit control and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Admiral Dryer Dead
  #1 (permalink)
Old 07-21-2009, 01:26 PM
Junior Member
Rfunaro is on a distinguished road
Default Maytag Admiral Dryer Dead
Model Number: ADE7000AYW   Brand: Admiral   Age: 5 - 10 years
Amiral Dryer Model ADE7000AYW s/n#15150625GC is dead. I changed the door switch, thermostat control,and the T-stat hi limit control and the unit is still dead! What else could it be? Please help!
Rich
rjfunaro@comcast.net
parts changed:
AP4039476 thermostat control
AP4056436 Stat hi limit control
359484 Door switch
Ads By Google
Related Models
Admiral ADE7000AYW Dryer - Ele
Admiral ADE7005AKW Dryer - Ele
Admiral ADE7005AYW Dryer - Ele
Maytag ADE808 Dryer - Ele
Admiral ADE9000AYW Dryer - Ele
Admiral ADE9005AGW Dryer - Ele
Whirlpool ADF07520
Whirlpool ADF07521
Whirlpool ADF07522
Whirlpool ADF10020
Whirlpool ADF10220
Whirlpool ADF11021
Whirlpool ADF12020
Whirlpool ADF12540
Whirlpool ADF13520
Whirlpool ADF13521
Whirlpool ADF13522
Whirlpool ADF13523
Whirlpool ADF17040
Whirlpool ADF18040
Whirlpool ADF18041
Whirlpool ADF18043
Whirlpool ADF18044
Whirlpool ADF18240
Whirlpool ADF21240
Whirlpool ADF21340
Whirlpool ADF21342
Whirlpool ADF21343
Whirlpool ADF29040
Whirlpool ADF29041
Whirlpool ADF29042
Whirlpool ADF29043
Whirlpool ADFC6320
Whirlpool ADFC6321
Whirlpool ADFC6322
Whirlpool ADFE1240
Whirlpool ADFE1241
Whirlpool ADFE1242
Whirlpool ADFE1540
Whirlpool ADFE1541
Whirlpool ADFE1542
Whirlpool ADFE1830
Whirlpool ADFE1831
Whirlpool ADFH0720
Whirlpool ADFH0721
Whirlpool ADFH2130
Whirlpool ADFP5020
Whirlpool ADFP5021
Whirlpool ADFP5022
Whirlpool ADFP5023
Whirlpool ADFP5520
Whirlpool ADFP6021
Whirlpool ADFP6022
Whirlpool ADFP8020
Whirlpool ADFP8021
Whirlpool ADFR1240
Whirlpool ADFS1020
Whirlpool ADFS1021
Whirlpool ADFS6020
Whirlpool ADFS6021
Whirlpool ADFS8020
Whirlpool ADFS8021
Whirlpool ADFS8022
Whirlpool ADFW0940
Whirlpool ADFW0941
Whirlpool ADFW0942
Whirlpool ADFW1240
Whirlpool ADFW1241
Whirlpool ADFW1242
Whirlpool ADFW1540
Whirlpool ADFW1541
Whirlpool ADFW1542
Whirlpool ADFW1543
Whirlpool ADFW1544
Maytag ADG107 Dryer - Gas
Admiral ADG20K2A Dryer - Gas
Admiral ADG20K2H Dryer - Gas
Admiral ADG20K2W Dryer - Gas
Admiral ADG20K3 Dryer - Gas
Admiral ADG20K3A Dryer - Gas
Admiral ADG20K3H Dryer - Gas
Admiral ADG20K3V Dryer - Gas
Admiral ADG20K3W Dryer - Gas
Admiral ADG20K4 Dryer - Gas
Admiral ADG20K4A Dryer - Gas
Admiral ADG20K4H Dryer - Gas
Admiral ADG20K4W Dryer - Gas
Admiral ADG20L1A Dryer - Gas
Admiral ADG20L1H Dryer - Gas
Admiral ADG20L1W Dryer - Gas
Admiral ADG20L2A Dryer - Gas
Admiral ADG20L2H Dryer - Gas
Admiral ADG20L2W Dryer - Gas
Admiral ADG20L4 Dryer - Gas
Admiral ADG20L4A Dryer - Gas
Admiral ADG20L4H Dryer - Gas
Admiral ADG20L4W Dryer - Gas
Admiral ADG20M3V Dryer - Gas
Admiral ADG20N3V Dryer - Gas
Maytag ADG308 Dryer - Gas
Maytag ADG309 Dryer - Gas
Maytag ADG408 Dryer - Gas
Maytag ADG409 Dryer - Gas
Maytag ADG608 Dryer - Gas
Admiral ADG7000AWW Dryer - Gas
Admiral ADG7005AWW Dryer - Gas
Maytag ADG808 Dryer - Gas
Admiral ADG9000AWW Dryer - Gas
Amana ADGS902E Range - S/c S/i Ddraft Gas
Amana ADGS902SS Range - S/c S/i Ddraft Gas
Amana ADGS902WW Range - S/c S/i Ddraft Gas
General Electric ADH15D3Z1 Room air conditioner
General Electric ADH18D1G1 Room air conditioner
General Electric ADH18D1G2 Room air conditioner
General Electric ADH18D1G3 Room air conditioner
General Electric ADH18D3E1 Room air conditioner
General Electric ADH23D1X1 Room air conditioner
General Electric ADH23D3B1 Room air conditioner
Whirlpool ADJ06020
Whirlpool ADJ07220
  #2 (permalink)
Old 07-22-2009, 11:22 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Before you get any more new parts, check this part for continuity.
Part number: AP4038936
If it, and all of the electrics check out your problem may be in the gas burner system.
__________________
  #3 (permalink)
Old 07-22-2009, 02:52 PM
Junior Member
Default
PArt numbers: AP 4056436 T-Stat Hi Limit
AP 4039476 Thermostat control
Door switch
All of the above parts have been changed win new parts.
Dryer still dead!
Your thoughts ??
  #4 (permalink)
Old 07-22-2009, 04:08 PM
Senior Expert
APP Volunteer
Default
Your machine has a cycling thermostat which it appears you have not checked.
__________________
  #5 (permalink)
Old 07-22-2009, 06:24 PM
Junior Member
Default
Where would I find this cycling theromostat, and what does it look like? I have had the front, top, and back of where the knobs are, and I don't see anything else that even remotely looks like a thermostat?????
  #6 (permalink)
Old 07-23-2009, 10:11 AM
Senior Expert
APP Volunteer
Default
It looks like the one in the picture. It should be on the blower housing. If you do not have one check to make sure you have 120 volts to each side of the connection block (I am assuming this is an electric dryer). If it is gas see the other posts on this Forum about gas coils and dryer not operating.
__________________
  #7 (permalink)
Old 09-29-2010, 09:49 PM
Junior Member
Guest is on a distinguished road
Default
This is an old post, but, I found it via a web search for the same problem with the same model dryer. For future reference, the problem with this dryer is/was the Thermal Fuse. It is located at the top rear left of the dryer towards the bottom of the heating element (little hard to see and to get to). The part number for this fuse is 53-1096 (or AP4056527), but, the suggested fix is to replace both it and the High-Limit Thermostat (part# 53-0771 or AP4056436 as noted in original post) as its failure to operate properly is what caused the fuse to blow. The High-Limit Thermostat is located just above the heating element and has a large blue sticker on it. Both these parts come in a kit that includes replacement parts for both electric and gas dryers. The part number for the repair kit is LA-1053 and is commonly available on the web for around $25. I found the best bargain on feeBay for about $12.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Dryer DEAD No Start Rattytattom Dryer Repair 5 11-07-2010 08:58 AM
maytag performa pyet344ayw dryer, dead.....AGAIN! noble26 Dryer Repair 1 12-10-2009 07:53 AM
dead dryer - Maytag leeandbrande Dryer Repair 2 12-06-2009 11:13 AM
Admiral Dryer Dead jeffh Dryer Repair 5 01-24-2008 03:12 PM
Dead Admiral Dryer jwboone1981 Dryer Repair 1 01-01-2008 01:59 AM
