Discuss
Dryer not producing heat
 in
Dryer Repair
I replaced the motor in this 15 year old unit a couple of months ago without much difficulty, and dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer not producing heat
  #1 (permalink)
Old 01-06-2008, 04:16 PM
Jeff B Jeff B is offline
Junior Member
Jeff B is on a distinguished road
Default Dryer not producing heat
Model Number: YG20JN-4   Brand: Magic Chef   Age: More than 10 years
I replaced the motor in this 15 year old unit a couple of months ago without much difficulty, and dryer worked again like new. Now just recently, unit will run but does not produce heat. Looking for possible suggestions of what to look at for troubleshooting. Igniter was the first item to come to mind. Am I close? Assistance please. Thanx.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-07-2008, 11:52 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Jeff,
The first thing I would check are the thermal fuse (on the air duct) and the hi limit thermostat (on the heater).
If any of them is open - replace both. The new part comes is a kit of the thermal fuse and the hi limit thermostat.
- The part number for the thermostat kit is AP415996
- Here are the break down diagrams for the Magic Chef dryer Model YG20JN4
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-26-2008, 10:40 PM
Junior Member
Default Dryer not producing heat.2
response to reply on 01/07 from Gene; re: (Whirlpool Gas Dryer-YG20JN4)
thank you for your first suggestion. i replaced both the thermal fuse and the hi level thermostat without producing the desired results. what would you recommend my next attempt should consist of?
Jeff B
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Dryer Heat Warren Dryer Repair 19 04-28-2008 09:24 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
No Dryer Heat jackd3 Dryer Repair 2 10-06-2007 01:32 PM
dryer won't heat deirdre williams Dryer Repair 0 09-28-2007 04:23 AM
gas dryer will not heat retcop320 Dryer Repair 1 09-11-2007 06:41 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
