| » kitchen aid dryer |
Model Number: keye677bwh2 Brand: Kitchen Aid Age: More than 10 years
kitchen aid dryer will not come on. I have power to the timer or switch, but the motor isnt coming on
Replacement parts for Whirlpool KEYE677BWH2 ELECTRIC DRYER | AppliancePartsPros.com See the attachment for the wiring diagram. I would start by checking the thermal fuse (Item 6 in Section 1) Unplug the unit and check the fuse with a meter should be 0 ohms. Jiggery Pokery method is. Unplug the unit. Remove both wires from the fuse, short them together and tape them up so they will not short to the frame. Plug the unit in and give it a try. If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires. Also clean/check your vent system and the blower as these are the most common causes of it blowing.
__________________
| Display Modes | |
| kitchen aid gas dryer - need help | George Sansom | Dryer Repair | 0 | 01-28-2012 01:19 PM |
| Kitchen Aid Electric Dryer | samiboy | Dryer Repair | 0 | 12-26-2011 09:29 AM |
| Kitchen Aid Dryer Help ! | elfd182 | Dryer Repair | 3 | 09-30-2009 06:01 AM |
| Kitchen Aid Gas Dryer | smitty6969 | Dryer Repair | 0 | 09-15-2009 06:39 PM |
| Kitchen Aid Superba Dryer | mike28086 | Dryer Repair | 1 | 05-01-2009 01:51 PM |
