| » Whirlpool Dryer |
Model Number: LER7646AQ0 Brand: Whirlpool Age: More than 10 years
I have a Whirlpool Dryer model LER7646AQO that runs but is not heating. My guess is that it has something to do with a fuse or heating element. Looking for suggestions on what to check first
Hi Juan
You will need a meter, or even better, a friend with a meter who will do this for you. 1. First check that you have 120 volts coming to each side of the connection block. 2. Unplug the dryer and test the thermal fuse and thermostats for continuity. 3. If this checks out, remove the heater coil and make certain it is not grounded or broken. Test its resistance, should be between 12 and 20 ohms. Good luck, let us know what you find out.
__________________
| Display Modes | |
| Burned Dryer Plug - Whirlpool Electric Dryer | EastCobbSnob | Dryer Repair | 4 | 11-17-2009 06:45 PM |
| whirlpool Dryer | Tammy43 | Dryer Repair | 1 | 11-04-2009 04:33 PM |
| Whirlpool Gas Dryer | SandraB | Dryer Repair | 3 | 07-24-2009 01:49 PM |
| Whirlpool Dryer Has no Heat in Dryer | jsanabia | Dryer Repair | 1 | 06-08-2009 04:36 PM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
