Discuss
trouble shooting electric dryer won't start
 in
Dryer Repair
My dryer will not start. I have replaced the following parts but none of them fix the problem: door dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » trouble shooting electric dryer won't start
  #1 (permalink)
Old 02-07-2012, 01:33 PM
Junior Member
Domenic711 is on a distinguished road
Default trouble shooting electric dryer won't start
Model Number: LEQ9858PW0   Brand: Whirlpool   Age: 5 - 10 years
My dryer will not start. I have replaced the following parts but none of them fix the problem: door dryer switch assembly, dryer thermal fuse, start switch, dryer thermal cut off kit, dryer drive motor abd blower wheel. Does anyone have any other suggestions or ideas on what the problem could be. The dryer will not go on. There is nothing wring with the electrical outlet. Thank you.
Related Models
Whirlpool LEQ9858PW0 29"ELECTRIC DRYER
Whirlpool LEQ9858PW1 29"ELECTRIC DRYER
Whirlpool LEQ9957KQ0 RESIDENTIAL DRYER
Whirlpool LEQ9957KT0 RESIDENTIAL DRYER
Admiral LER1115AAW RANGE- F/S STD ELE
Whirlpool LER2614BW0 ELECTRIC DRYER
Whirlpool LER2614BW1 ELECTRIC DRYER
Whirlpool LER2614BW2 ELECTRIC DRYER
Whirlpool LER2614DW0 ELECTRIC DRYER
Whirlpool LER2614DW1 ELECTRIC DRYER
Whirlpool LER2614EW0 ELECTRIC DRYER
Whirlpool LER2614EW1 ELECTRIC DRYER
Whirlpool LER2614EW2 ELECTRIC DRYER
Whirlpool LER2614JQ0 ELECTRIC DRYER
Whirlpool LER2614JQ1 ELECTRIC DRYER
Whirlpool LER2614JQ2 29"ELECTRIC DRYER
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB RANGE- S/C F/S ELE
Admiral LER3330AAW RANGE- S/C F/S ELE
Admiral LER3330AAZ RANGE- S/C F/S ELE
Whirlpool LER3422AW0 Residential Dryer
Whirlpool LER3424AW0 Residential Dryer
Whirlpool LER3622BN0 COMPACT ELECTRIC DRYER
Whirlpool LER3622BW0 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622DZ2 COMPACT ELECTRIC DRYER
Whirlpool LER3622HQ0 DRYER
Whirlpool LER3622HQ1 RESIDENTIAL DRYER
Whirlpool LER3622PQ0 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ1 COMPACT ELECTRIC DRYER
Whirlpool LER3622PQ2 COMPACT ELECTRIC DRYER
Whirlpool LER3624BN2 ELECTRIC DRYER
Whirlpool LER3624BN3 ELECTRIC DRYER
Whirlpool LER3624BW0 ELECTRIC DRYER
Whirlpool LER3624BW1 ELECTRIC DRYER
Whirlpool LER3624BW2 ELECTRIC DRYER
Whirlpool LER3624BW3 ELECTRIC DRYER
Whirlpool LER3624DQ0 DRYER
Whirlpool LER3624DQ1 ELECTRIC DRYER
Whirlpool LER3624DQ2 ELECTRIC DRYER
Whirlpool LER3624DZ0 DRYER
Whirlpool LER3624DZ2 ELECTRIC DRYER
Whirlpool LER3624EQ0 LAUNDRY DRYERS
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
  #2 (permalink)
Old 02-07-2012, 05:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Domenic,
I understand your feelings, but I have just one question - did you test any of the parts you replaced prior to replace them? A simple multimeter for less than $20 can save you time and $$$.
I would suggest to get a meter and start over the troubleshooting step by step.
Is the dryer completely dead or it does anything like a noise or maybe inside light goes on?
Let us know when you'll get a meter and we'll guide you through the troubleshooting.
You can return any unneeded part, if you purchased it from APP.
Here are the breakdown diagrams and Replacement parts for Whirlpool LEQ9858PW0 29"ELECTRIC DRYER | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-08-2012, 03:44 PM
Junior Member
Default
we had the parts all tested with the meter and also had a service man come out and he tested them all. He told us we needed a new motor. The light does turn on when plugged in and it does make the ticking noise when plugged in as well. Thank you for your help
  #4 (permalink)
Old 02-08-2012, 03:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Domenic711 View Post
...we had the parts all tested with the meter...
That means all tested parts did not pass the tests and that's why you replaced them? Too many parts at the same time.
Can you describe exactly, step by step, how did you test these parts please?
__________________
  #5 (permalink)
Old 02-10-2012, 05:39 AM
Junior Member
Default
Thank you gene. We checked and ordered each part individually. Since we did not have a meter of our own we took each part to either home depot or sears and they checked for us. We replaced each part one at a time and then checked to see if that fixed the issue. Once the repairman came out we we thought for sure the new motor would fix it.
We appreciate your help with this.
  #6 (permalink)
Old 02-10-2012, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Domenic,
I would recommend in such situation to buy a simple multimeter (digital or analog) and redo all tests by yourself. You can order one from APP or buy it from Radio Shack.
The following article on our forum will explain in detail how to run a continuity test using either an analog or a digital meter - How To Check Continuity With Ohmmeter.
- The simple digital multimeter Part number: AP3440648
__________________
  #7 (permalink)
Old 02-15-2012, 03:59 PM
Junior Member
Default
I hope I explained it right. We checked each part separately. We would purchase one part, replace it and then plug the dryer in to see if it worked. One by one we replaced all the parts that I mentioned earlier. The last part we replaced was the motor which a technician told us was the issue.
Is there another part or anything else we need to check?
  #8 (permalink)
Old 02-16-2012, 12:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Domenic,
Would you believe it or not but I don't trust such test results done by a store people. Especially because the results are very strange. That's why I asked you to redo all tests by yourself. I know you can do it better, follow the instructions mentioned above.
__________________
  #9 (permalink)
Old 02-21-2012, 08:19 PM
Junior Member
gsydor is on a distinguished road
Default same problems with maytagemde6700ayw
also have a dryer that will not start checked all switches thermal fuses door belt switches every one i removed them from dryer when this was done had two techs out neither one could find the problem voltage is ok but when pluged in i get is a small huming noise from the left side near the maine control pannel was thinking of buying anew board but dont know if its returnable amny luck with yours/
  #10 (permalink)
Old 02-22-2012, 03:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the wires from the motor relay at the control board (the upper relay on the left side of the picture) and check for continuity between the relay terminals while the control calls for dry.
Replace the control board if there is no continuity.
- The control board Part number: AP4045210
Here are the breakdown diagrams and Replacement parts for Maytag MDE6700AYW DRYER- ELE | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
trouble shooting jda1957 Oven Repair (including Ranges and Cooktops) 0 01-18-2012 11:36 AM
Ice Maker trouble shooting Pat13 Refrigerator & Freezer Repair 1 12-06-2010 12:26 PM
Trouble shooting lojeke Refrigerator & Freezer Repair 1 11-14-2009 01:58 AM
trouble shooting kc jones1 Washer Repair 1 06-08-2009 09:35 AM
Trouble shooting AJK Oven Repair (including Ranges and Cooktops) 0 04-17-2008 06:55 AM
