| » Fixing Fins that Came Loose (White-Westinghouse Spacemates) |
Model Number: LG400AXW1 Brand: White-Westinghouse Age: 5 - 10 years
I have a White Westinghouse Spacemates dryer model LG400AXW1.
One of the two screws holding a fin has come off, the other is loose on the same fin. Since they are not accessible from the fin side, how do I access the screws on the back side of the drum? Thanks in advance Ads By Google Related Models |
I'm assuming the part you called "fin" is a vane (#30 on the diagram). If this is correct then you have to lift up the top panel to access these screws.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE LG400AXW1 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
I was able to complete the repair to the vanes last night.
The screws that hold the top sheet metal plate (not a clip on style enameled top) were very very tight. It required WD-40, then a heat gun until it got pretty hot and then an impact driver. Curse them for using philips head round screws so I couldn't use a hex socket on it. I replace with hex screws, slightly stouter. All the vanes were missing the middle screw, plus one more one the one that started flopping loose. I wonder if the manufacturer didn't put any on the middle point or if all 3 middle screws had already fallen out over the years. Anyway, I replace all missing screws with slightly stouter ones, all hex head. Thanks for your help getting me through this! |
You are welcome. I'm glad you were able to fix it. Thenk you for your feed back and good luck with your dryer.
__________________
| Display Modes | |
| White Westinghouse Spacemate | dorothea | Washer Repair | 8 | 09-13-2009 09:06 PM |
| White Westinghouse Spacemate | dorothea | Washer Repair | 0 | 09-05-2009 12:44 PM |
| white westinghouse 2 speed | washing momma blues | Washer Repair | 1 | 12-15-2008 05:08 PM |
| Please Help.....White Westinghouse Spacemates | oceanmaid | Dryer Repair | 1 | 09-05-2008 04:16 PM |
| White-Westinghouse SpaceMates Washer/Dryer | Simsin | Dryer Repair | 3 | 04-15-2008 09:44 PM |
