| » Gas dryer, no heat |
Model Number: GLGR341AS4 Brand: Electrolux Age: 1 - 5 years
(I actually have no idea how old the dryer is - I know it's at least a few years old.)
Gas dryer has absolutely no heat. I read online somewhere to test the resistance of the igniter. I didn't have a multimeter, but I went out and purchased a digital one and followed the instructions for resistance testing. I unplugged the connector for the igniter and tested for resistance at the connector and the default reading on the multimeter never changed. I'm not sure how to interpret that. Does that mean the igniter is definitely bad? or maybe my multimeter isn't working correctly? Or maybe there's a short in the wiring between the igniter and the connector? Are there other parts I should be looking at/testing as well? Thanks in advance for any help you can give me! Oh, one other bit of info that may or may not be relevant. Earlier this year the basement where the dryer is located was flooded for a few days - 4 to 6 inches of water. That was about 2.5 months ago. The dryer has worked just fine since then - i.e. with heat. But I'm wondering if the water could have started damaging one of the parts and it just took awhile for the damage to show itself? I also started the dryer in the dark with the top lifted up, looking down towards the front left corner of the dryer, and never saw any light/glow from that area like I presumably would have if the igniter was doing anything at all. Ads By Google Related Models Last edited by jessman1128 : 07-20-2009 at 08:33 AM. Reason: Added last paragraph. |
The result of the igniter test you received can be due to a bad igniter (∞ resistance) or you did something wrong.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter. Redo the test and post the result. Here are the breakdown diagrams and Replacement parts for FRG GLGR341AS4 | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
| Dryer will not heat. It tumbles and cycles but it will not emit any heat. | agentsmith0505 | Dryer Repair | 0 | 10-14-2009 09:44 AM |
| Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. | NEAL AMES | Dryer Repair | 1 | 01-02-2009 06:40 PM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
