Discuss
gas flame will not ignite
 in
Dryer Repair
My gas dryer will not heat up. I have checked it out and found that if I short out either
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas flame will not ignite
  #1 (permalink)
Old 07-20-2009, 05:45 AM
Junior Member
heslington is on a distinguished road
Default gas flame will not ignite
Model Number: LDG410   Brand: Maytag   Age: More than 10 years
My gas dryer will not heat up. I have checked it out and found that if I short out either of the two thermostates located down by the blower unit the electric igniter will heat up and the gas flame will ignite.
My question is how to verify if the thermostates are good or defective.
I have ohmed out the thermostates and found the following condition on both of them.
On one side there is only one terminal and on the other side there are two terminals. When I place on ohm meter lead on the side with one terminal and the other lead on the lower terminal on the other side I get some resistance but it is not very much. When I leave the lead on the side with only one terminal and move the other lead to the upper terminal I get an open condition. Is this correct? Or is the thermostate bad?
I did not measure the resistance between the two terminal on the same side.
Thanks for you help.
Heslington
Ads By Google
Related Models
Maytag LDG410 Dryer - Gas
Maytag LDG412 Dryer - Gas
Maytag LDG412D Dryer - Gas
Maytag LDG482 Dryer - Gas
Maytag LDG482D Dryer - Gas
Maytag LDG490 Dryer - Gas
Maytag LDG490D Dryer - Gas
Maytag LDG4910 Dryer - Gas
Maytag LDG4910AAL Dryer - Gas
Maytag LDG4910AAW Dryer - Gas
Maytag LDG4914AAE Dryer - Gas
Maytag LDG4914AAL Dryer - Gas
Maytag LDG4914AAM Dryer - Gas
Maytag LDG4916AAE Dryer - Gas
Maytag LDG4916AAM Dryer - Gas
Maytag LDG5004AAW Dryer - Gas
Maytag LDG5004ABW Dryer - Gas
Maytag LDG5005AAE Dryer - Gas
Maytag LDG5005ABE Dryer - Gas
Maytag LDG510 Dryer - Gas
Maytag LDG512 Dryer - Gas
Maytag LDG512D Dryer - Gas
Maytag LDG590 Dryer - Gas
Maytag LDG590D Dryer - Gas
Maytag LDG5910 Dryer - Gas
Maytag LDG5910AAL Dryer - Gas
Maytag LDG5910AAW Dryer - Gas
Maytag LDG5914AAE Dryer - Gas
Maytag LDG5914AAL Dryer - Gas
Maytag LDG5914AAM Dryer - Gas
Maytag LDG5916AAE Dryer - Gas
Maytag LDG5916AAM Dryer - Gas
Maytag LDG6004AAW Dryer - Gas
Maytag LDG606 Dryer - Gas
Maytag LDG608 Dryer - Gas
Maytag LDG610 Dryer - Gas
Maytag LDG612 Dryer - Gas
Maytag LDG612D Dryer - Gas
Maytag LDG6914AAE Dryer - Gas
Maytag LDG6914AAL Dryer - Gas
Maytag LDG6914AAM Dryer - Gas
Maytag LDG710 Dryer - Gas
Maytag LDG712 Dryer - Gas
Maytag LDG713 Dryer - Gas
Maytag LDG7304AAE Dryer - Gas
Maytag LDG7304AAL Dryer - Gas
Maytag LDG7304AAM Dryer - Gas
Maytag LDG7304ABE Dryer - Gas
Maytag LDG7304ABL Dryer - Gas
Maytag LDG7304ABM Dryer - Gas
Maytag LDG7304AGE Dryer - Gas
Maytag LDG7304AGL Dryer - Gas
Maytag LDG7304AGM Dryer - Gas
Maytag LDG7304EGE Dryer - Gas
Maytag LDG7304EGL Dryer - Gas
Maytag LDG7304EGM Dryer - Gas
Maytag LDG7314AAE Dryer - Gas
Maytag LDG7314AAL Dryer - Gas
Maytag LDG7314AAM Dryer - Gas
Maytag LDG7334AAE Dryer - Gas
Maytag LDG7334AAL Dryer - Gas
Maytag LDG7334AAM Dryer - Gas
Maytag LDG7400 Dryer - Gas
Maytag LDG7400AAL Dryer - Gas
Maytag LDG7400AAW Dryer - Gas
Maytag LDG7400ABL Dryer - Gas
Maytag LDG7400ABW Dryer - Gas
Maytag LDG7480AAL Dryer - Gas
Maytag LDG7480AAW Dryer - Gas
Maytag LDG7480ABL Dryer - Gas
Maytag LDG7480ABW Dryer - Gas
Maytag LDG7500 Dryer - Gas
Maytag LDG7500AAE Dryer - Gas
Maytag LDG7500AAL Dryer - Gas
Maytag LDG7500AAM Dryer - Gas
Maytag LDG7500AAW Dryer - Gas
Maytag LDG7500ABE Dryer - Gas
Maytag LDG7500ABL Dryer - Gas
Maytag LDG7500ABM Dryer - Gas
Maytag LDG7500ABW Dryer - Gas
Maytag LDG7600 Dryer - Gas
Maytag LDG7600AAG Dryer - Gas
Maytag LDG7600AAL Dryer - Gas
Maytag LDG7600AAW Dryer - Gas
Maytag LDG7600ABL Dryer - Gas
Maytag LDG7600ABW Dryer - Gas
Maytag LDG7600AGG Dryer - Gas
Maytag LDG7600AGL Dryer - Gas
Maytag LDG7600AGW Dryer - Gas
Maytag LDG7800 Dryer - Gas
Maytag LDG7800AAL Dryer - Gas
Maytag LDG7800AAW Dryer - Gas
Maytag LDG7800ABL Dryer - Gas
Maytag LDG7800ABW Dryer - Gas
Maytag LDG8000 Dryer - Gas
Maytag LDG8000AAL Dryer - Gas
Maytag LDG8000AAW Dryer - Gas
Maytag LDG8000ABL Dryer - Gas
Maytag LDG8000ABW Dryer - Gas
Maytag LDG808 Dryer - Gas
Maytag LDG810 Dryer - Gas
Maytag LDG8200 Dryer - Gas
Maytag LDG8200AAE Dryer - Gas
Maytag LDG8200AAL Dryer - Gas
Maytag LDG8200AAW Dryer - Gas
Maytag LDG8200ABE Dryer - Gas
Maytag LDG8200ABL Dryer - Gas
Maytag LDG8200ABW Dryer - Gas
Maytag LDG8300 Dryer - Gas
Maytag LDG8300AAL Dryer - Gas
Maytag LDG8300AAW Dryer - Gas
Maytag LDG8304AAE Dryer - Gas
Maytag LDG8304AAL Dryer - Gas
Maytag LDG8304AAM Dryer - Gas
Maytag LDG8404AAE Dryer - Gas
Maytag LDG8404AAL Dryer - Gas
Maytag LDG8404AAM Dryer - Gas
Maytag LDG8404ABE Dryer - Gas
Maytag LDG8406AAE Dryer - Gas
Maytag LDG8406AAM Dryer - Gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Flame Is Yellow And High. Flame Doesn't Regulate COOLJADE Oven Repair (including Ranges and Cooktops) 0 02-25-2010 03:28 PM
Flame will not ignite brinan Dryer Repair 5 02-14-2010 04:10 PM
flame will not keep lit dme1 Dryer Repair 1 09-12-2009 05:58 PM
No Flame jmcbride421 Dryer Repair 0 08-09-2009 10:10 AM
flame on but then goes out zorst Dryer Repair 2 01-18-2009 10:55 PM
