Discuss
Kenmore dryer heats okay but slows then stops
 in
Dryer Repair
I'm helping a friend with her sick dryer which starts okay but runs slowly then slows and stops within 5
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer heats okay but slows then stops
  #1 (permalink)
Old 07-19-2009, 12:22 PM
Junior Member
Espritman is on a distinguished road
Default Kenmore dryer heats okay but slows then stops
Model Number: 86681100   Brand: Kenmore   Age: More than 10 years
I'm helping a friend with her sick dryer which starts okay but runs slowly then slows and stops within 5 minutes. What should I look for?
Thanks,
Espitman
Ads By Google
Related Models
Magic Chef 8670PB SURFACE UNIT- ELE
Magic Chef 8670PV SURFACE UNIT- ELE
Magic Chef 8670RB SURFACE UNIT- ELE
Magic Chef 8670RV SURFACE UNIT- ELE
Jenn-Air 86732 MISC / ACCESSORY
Amana 86851 REF - TOP MOUNT
Frigidaire 86851-0A FREEZER
Frigidaire 86851-0B FREEZER
Frigidaire 86851-0D FREEZER
Amana 86855 REF - TOP MOUNT
Amana 86858 REF - TOP MOUNT
Amana 86861 REF - TOP MOUNT
Amana 86861W REF - TOP MOUNT
Amana 86868 REF - TOP MOUNT
Amana 86868L REF - TOP MOUNT
Amana 86871 REF - TOP MOUNT
Amana 86878 REF - TOP MOUNT
Magic Chef 86HA-1 SURFACE UNIT- ELE
Magic Chef 86HK-1 SURFACE UNIT- ELE
Magic Chef 86HN-1 SURFACE UNIT- ELE
Magic Chef 86HS-1 SURFACE UNIT- ELE
Magic Chef 86HY-1 SURFACE UNIT- ELE
Magic Chef 86LA-1 SURFACE UNIT- ELE
Magic Chef 86LK-1 SURFACE UNIT- ELE
Magic Chef 86LN-1 SURFACE UNIT- ELE
Magic Chef 86LS-1 SURFACE UNIT- ELE
Magic Chef 86LW-1 SURFACE UNIT- ELE
Hoover 87
Amana 8700.A MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8710PA SURFACE UNIT- ELE
Magic Chef 8710PB SURFACE UNIT- ELE
Magic Chef 8710PS SURFACE UNIT- ELE
Magic Chef 8710PW SURFACE UNIT- ELE
Magic Chef 8710VB SURFACE UNIT- ELE
Magic Chef 8710VD SURFACE UNIT- ELE
Magic Chef 8710VS SURFACE UNIT- ELE
Magic Chef 8710VV SURFACE UNIT- ELE
Magic Chef 8720PA SURFACE UNIT- ELE
Magic Chef 8720PS SURFACE UNIT- ELE
Magic Chef 8720PW SURFACE UNIT- ELE
Magic Chef 8720VB SURFACE UNIT- ELE
Magic Chef 8720VD SURFACE UNIT- ELE
Magic Chef 8720VQ SURFACE UNIT- ELE
Magic Chef 8720VS SURFACE UNIT- ELE
Magic Chef 8720VV SURFACE UNIT- ELE
Amana 874.000 RANGE- S/C S/I DDRAFT GAS
Amana 874.001 RANGE- S/C S/I DDRAFT GAS
Amana 874.301 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.302 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.304 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.305 MWAVE - FAMILY SIZE (60 HZ)
Amana 876.A MWAVE - FAMILY SIZE (60 HZ)
Amana 876.B MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8770RB SURFACE UNIT- ELE
Magic Chef 8770RV SURFACE UNIT- ELE
Jenn-Air 87848 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87849 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87899 MISC / ACCESSORY
Jenn-Air 87904 ELE CARTRIDGE
Jenn-Air 87914 MISC / ACCESSORY
Jenn-Air 87919 MISC / ACCESSORY
Niagra 8795-0 4000 WATT PORTABLE AC GENERATOR
Magic Chef 87LA-1 SURFACE UNIT- ELE
Magic Chef 87LA-1G SURFACE UNIT- ELE
Magic Chef 87LK-1 SURFACE UNIT- ELE
Magic Chef 87LN-1 SURFACE UNIT- ELE
Magic Chef 87LN-1G SURFACE UNIT- ELE
Magic Chef 87LS-1 SURFACE UNIT- ELE
Magic Chef 87LS-1G SURFACE UNIT- ELE
Hoover 88
Amana 880.000 RANGE- S/C S/I DDRAFT GAS
Amana 880.001 RANGE- S/C S/I DDRAFT GAS
Amana 880.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 880.003 RANGE- S/C S/I DDRAFT GAS
Amana 880.004 RANGE- S/C S/I DDRAFT GAS
Amana 880.110 RANGE- S/C S/I DDRAFT GAS
Amana 880.120 RANGE- S/C S/I DDRAFT GAS
Amana 880.130 RANGE- S/C S/I DDRAFT GAS
Amana 880.130*1 LITTON BUILT-IN WALL OVEN
Amana 880.130x1 RANGE- S/C S/I DDRAFT GAS
Frigidaire 88057-7A CHEST FREEZER
Whirlpool 880652124P0 30" ELECTRIC CERAN FREESTANDING RANGE STANDARD CLEAN OVEN
Frigidaire 88157-7A CHEST FREEZER
Frigidaire 88158-7A CHEST FREEZER
Frigidaire 88158A CHEST FREEZER
Frigidaire 88161-0A FREEZER
Frigidaire 88161-0B FREEZER
Frigidaire 88161-0D FREEZER
Jenn-Air 88168 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88169 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88170 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88186 MISC / ACCESSORY
Frigidaire 88258-7A FREEZER
Frigidaire 88258-7B FREEZER
Frigidaire 88269A CHEST FREEZER
Frigidaire 88269B CHEST FREEZER
Jenn-Air 88353 SURFACE UNIT- ELE
Jenn-Air 88353-8 SURFACE UNIT- ELE
Jenn-Air 88368 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88369 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88370 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88371 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88372 RANGE- F/S STD DDRAFT ELE
Whirlpool 885450 ELECTRIC DRYER
Whirlpool 885453 ELECTRIC DRYER
Whirlpool 885455 ELECTRIC DRYER
Whirlpool 885456 ELECTRIC DRYER
Whirlpool 885457 ELECTRIC DRYER
Whirlpool 885458 ELECTRIC DRYER
Whirlpool 885461 ELECTRIC DRYER
Whirlpool 885462 ELECTRIC DRYER
Whirlpool 885463 ELECTRIC DRYER
Whirlpool 885464 ELECTRIC DRYER
Whirlpool 885465 ELECTRIC DRYER
Whirlpool 885468 ELECTRIC DRYER
Whirlpool 885469 ELECTRIC DRYER
Whirlpool 885472 ELECTRIC DRYER
KitchenAid 885779 SIDE-BY-SIDE REFRIGERATOR
  #2 (permalink)
Old 07-21-2009, 10:41 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I assume that when you say it slows you are talking about the motor sllowing and the drum slowing until it stops.
Sounds very much like the motor is failing. How long after it stops do you have to wait until you can start it up again?
__________________
  #3 (permalink)
Old 07-22-2009, 06:05 AM
Junior Member
Default
Thank you, Sidfink
Approximately 24 hour to start again.
  #4 (permalink)
Old 07-22-2009, 07:49 AM
Junior Member
Default
Quote:
Originally Posted by Espritman View Post
Thank you, Sidfink
sidfink43,
I've removed the rear panel of the Kenmore dryer. There does not appear to be easy access to the drive motor which, although I cannot see it fully, a flashlight shown through one of the access holes at the right bottom, allows me to see that the motor appears to be located under the drum in the left hand corner as I face the rear of the machine. I was able to raise the top of the dryer which gave me access to 2 corner screws removable from the inside. The front panel is now attached only at the bottom. Do I access the motor by removing this front panel? If so, what holds it to the bottom of the dryer? If not, how do I access the drum drive motor? Once I do that, can the motor be removed and lubricated in hopes that will solve the problem or must I purchase a new motor? Thank you for your excellent support.
Espritman
  #5 (permalink)
Old 07-22-2009, 09:46 AM
Senior Expert
APP Volunteer
Default
You have it right.
After you take off the front (it lifts off) you can remove the drum (after releasing the belt) and that will allow you to access the motor.
I do not think lubricating the motor will solve the problem, but you can certainly try that route. The symptoms you describe are those of a motor which overheats as it is failing, then cools down, and is able to run again briefly.
I wish we could be more definitive because the motor is relatively expensive, but given that the dryer works at least part of the time the diagnosis would point to the motor.
Good luck, let us know what happens.
__________________
  #6 (permalink)
Old 07-22-2009, 01:22 PM
Junior Member
juancar92236 is on a distinguished road
Default
if u can use a ampro to see how many amps your motor is using if the motor works with more of the amps that is espicify by the motor plate that cause the over heating
  #7 (permalink)
Old 07-24-2009, 01:18 PM
Junior Member
Default
It lifts off..... geez. I won't be near the machine again for a couple of weeks. In the meanwhile, she's taking your advice, using the dryer briefly and then the 'never fails' solution.
You said the motor is expensive - can you give me an approximate or range, $50, $100, $150? Thank you again.
  #8 (permalink)
Old 07-24-2009, 01:36 PM
Senior Expert
APP Volunteer
Default
Here is the motor for your machine, actually not too bad
Part number: AP3094245
Good luck, hope this does the job.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite H3 - Heats up initially but then stops heating. anonymouscuban Dryer Repair 2 01-07-2010 07:52 PM
Gas dryer heats then stops heating tdl340 Dishwasher Repair 1 12-30-2009 01:10 PM
Kenmore Elite dryer heats then stops toothfxr Dryer Repair 0 09-06-2009 08:12 AM
gas dryer heats then stops heating tomg19 Dryer Repair 0 07-25-2009 02:39 PM
Washer agitates normal then slows down and stops. jnaylor Washer Repair 3 10-22-2007 07:14 PM
