Discuss
Dryer does not spin
 in
Dryer Repair
My electric dryer stopped mid cycle and will not restart. When the timer is set you can still hear it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not spin
  #1 (permalink)
Old 01-05-2008, 06:31 PM
nospin nospin is offline
Junior Member
nospin is on a distinguished road
Unhappy Dryer does not spin
Model Number: pye4500ayw   Brand: Maytag   Age: 1 - 5 years
My electric dryer stopped mid cycle and will not restart. When the timer is set you can still hear it running and when the door is opened the light does not come on. I have checked the bulb and it is good. If the door switch is bad would the light remain of or come on. In other words does the door switch fail in the door open position. Would the thermal fuse affect the door light?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-06-2008, 06:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the thermal fuse. It is located on the heater box. If it's open - it has to be replaced together with the hi limit thermostat.
If there is nothing wrong with the thermal fuse, then check the door switch. It has three terminals: common (COM), normally open (NO) and normally closed (NC). Remove the wire from the common (COM) terminal and check continuity across the COM and the NO and the COM and the NC with the door open and closed.
The readings should be:
1. The door open : COM & NO - ∞ Ohms, COM & NC - 0 Ohms;
2. The door closed: COM & NO - 0 Ohms, COM & NC - ∞ Ohms.
- The part number for the thermal fuse kit is AP415996
- The part number for the door switch is AP311176
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-06-2008, 06:38 PM
Junior Member
Default
Thanks Gene. I located the thermal fuse on the lower right side of the heater box and jumped it momentarily and everything worked. WIll order the parts tonight. Thank you again for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't spin/tumble net Dryer Repair 1 12-02-2007 04:35 PM
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 09:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
