Discuss
Drum lip on dryer has become so sharp, it's cutting the drum glide and bracket
 in
Dryer Repair
Someone put some very wet, very heavy clothes into our dryer. Almost immediately it started to make a grinding noise.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Drum lip on dryer has become so sharp, it's cutting the drum glide and bracket
  #1 (permalink)
Old 02-02-2012, 05:13 PM
Junior Member
dnh_repairgirl is on a distinguished road
Default Drum lip on dryer has become so sharp, it's cutting the drum glide and bracket
Model Number: sgd4606aww   Brand: Maytag   Age: 5 - 10 years
Someone put some very wet, very heavy clothes into our dryer. Almost immediately it started to make a grinding noise. After taking the dryer apart, I could see metal dust at the bottom of the machine, just below one of the cylinder glide brackets. I could see that both the dryer glide and felt pad was broken/missing on that same cylinder glide bracket. I could also feel that our dryer drum had an extremely sharp edge around the outside, presumably the thing that was causing the grinding noise and the metal dust (the dryer drum against the metal cylinder glide bracket).
I replaced both the dryer glide and felt pad, reassembled, and ran the dryer. It ran quietly and somewhat successfully, until we put clothes in. Almost immediately it began making the grinding noise. So, I took it apart again, and now, I see that one of the cylinder glide brackets is almost completely cut in two, a result of the very sharp edge of the dryer drum, cutting through the bracket.
So, my question is, do I need a whole new drum or did I replace the glides wrong or is there something else at play here all together?
Help!
Related Models
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
White Westinghouse SGR351HQ0 DRYER
White Westinghouse SGR351HQ1 DRYER
White Westinghouse SGR351HS0 DRYER
White Westinghouse SGR351HS1 DRYER
White Westinghouse SGR641HQ0 DRYER
White Westinghouse SGR641HQ1 DRYER
White Westinghouse SGR641HS0 DRYER
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
Thermador SGSX365ZB
Thermador SGSX365ZS
Thermador SGSX365ZW
Thermador SGSX456ZB
Thermador SGSX456ZS
Thermador SGSX456ZW
Thermador SGT3001 COOKTOP
Thermador SGT3002 COOKTOP
Thermador SGT36 COOKTOP
Thermador SGT3601 COOKTOP
Thermador SGT36G01 COOKTOP
Thermador SGT36G02 COOKTOP
Frigidaire SGWS1349AS0 Frigidaire/washer
Bosch SGZ1000
Bosch SGZ1005
Bosch SGZ1024
Bosch SGZ1025
  #2 (permalink)
Old 02-07-2012, 05:26 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find any info on this unit.
Are you sure it is not a sdg4606aww and not sgd.
Below are parts for a sdg.
http://www.appliancepartspros.com/pa...del_id=5172909
Without being there I cannot say.
If you click on the part's picture a new page will open often with more views perhaps seeing the actual part will help you decide.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clothes getting STUCK in the drum glide asb237 Dryer Repair 1 09-10-2010 07:19 AM
Dryer drum glide-Amana gwh33@bellsouth.net Dryer Repair 3 06-21-2009 03:37 PM
Amana Dryer front drum glide jnr Dryer Repair 0 04-23-2009 09:48 AM
Glide Drum / rusting drum erniedoeg Dryer Repair 1 03-04-2009 10:08 AM
mAYTAG GAS DRYER DRUM GLIDE BRACKET REPLACEMENT Steve@Hilo Dryer Repair 1 02-27-2008 12:00 PM
