It had dried the previous load fine, then put in a small load, it stopped mid cycle. I've reset brakers, unpluged and repluged to outlet. Turned dial to various settings, nothing happens. It's like there is no electricity to it.
There was quite a bit of lit in the dryer hose, I cleaned it out along with area on dryer to hose. Thanks,
I would check the thermal fuse and the overload on the motor.
It is probably the fuse, but how do I get to it. I took off the back panel for the timer etc., but the fuse isn't there. The back panel for the dryer is molded with the sides, lots of bolts, do I take all of them off. thanks,
