Discuss
Dryer has no heat
 in
Dryer Repair
I have replaced the Fixed thermastat and Heating element. When I was first checking the leads tothe fixed thermatat the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer has no heat
  #1 (permalink)
Old 07-16-2009, 07:33 PM
Junior Member
tlpyle is on a distinguished road
Default Dryer has no heat
Model Number: LER5636JQ0   Brand: Whirlpool   Age: 5 - 10 years
I have replaced the Fixed thermastat and Heating element. When I was first checking the leads tothe fixed thermatat the lead broke off very easily and looked corroded. I checked the heating element's continutiy and it read 9.7 so I replaced it. I went ahead and changed the Thermal Fuse and still no heat. I have 240v coming in. The other two thermastats seem to have continuity. What else could be wrong?
Thanks and Frustrated!!
Ads By Google
Related Models
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
Whirlpool LER6848AN0
Whirlpool LER6848AN1
Whirlpool LER6848AN2
Whirlpool LER6848AQ2
Whirlpool LER6848AW0
Whirlpool LER6848AW1
Whirlpool LER6848AW2
Whirlpool LER6848AZ2
Whirlpool LER7620KQ0
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
Whirlpool LER7620LQ0
Whirlpool LER7620LW0
Whirlpool LER7620LW1 29"electric Dryer
Whirlpool LER7646AN0
Whirlpool LER7646AN1
  #2 (permalink)
Old 07-16-2009, 08:20 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Is this consistent in all cycles?
  #3 (permalink)
Old 07-16-2009, 08:37 PM
Junior Member
Default
Yes, I tried all cycles.
  #4 (permalink)
Old 07-16-2009, 09:10 PM
Senior Expert
APP Volunteer
Default
The thermostats and thermal fuse are wired in series with the heat element. If you'll disconnect the first wire in the series from the element to the first tstat, and the last wire out of the last tstat, See if there is continuity through all three components. You may also see continuity through the entire chain by adding the element, but it also adds quite a bit of resistance to the test.
If you do get continuity in these tests, I would suspect the timer.
  #5 (permalink)
Old 07-17-2009, 04:34 AM
Junior Member
Default
The continuity seemed to be okay when I checked with your instructions. I have attached a picture of the power cord connections. I noticed the wire on the left was corroded and somewhat black compared to the other two. I traced the wire (it is black) and it goes to the timer.
Maybe a stretch but I thought it may be worth a shot. I have not priced the power cord yet.
Your thoughts?
  #6 (permalink)
Old 07-19-2009, 04:36 PM
Senior Expert
APP Volunteer
Default
You should be getting 220-240VAC between the left and right connectors. You should get 118-120VAC between either of the outside connectors and the middle one. Unplug the core and check for continuity along each individual leg of the cord.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
