| » Amana Electric Dryer makes noise |
Model Number: LE8317W2 Brand: Amana Age: 5 - 10 years
The dryer begins to make a vibrational noise within 5 minutes of running. I cleaned the idlers and support bearings, they move smoothly, I ran the motor by itself, it seemed ok, the rest of the unit is clean inside and everything appears ok. When I put it back together without the lower cover I can see the belt vibrate as the noise begins to appear. The blower assy looks ok. I suspect the motor has an issue?? Thanks
Hi SVCtech
I would replace both the drum support and the idler, as they are probably your problem. I don't think it is likely the motor is the issue, but if the new idler and support wheels do not fix it let us know. Good luck.
__________________
| Display Modes | |
| dryer makes a loud noise | julieellis | Dryer Repair | 1 | 02-25-2010 06:51 AM |
| DRYER makes loud noise | geovonwilliams@bellsouth. | Dryer Repair | 3 | 02-24-2010 06:36 AM |
| grandma's gas dryer makes noise | tonja4 | Dryer Repair | 2 | 06-19-2009 10:38 PM |
| Dryer Makes Noise | mjkleinman | Dryer Repair | 4 | 05-08-2009 05:20 AM |
| Dryer makes clanking noise | Leonard07 | Dryer Repair | 2 | 12-05-2007 02:45 PM |
