Discuss
Heats up initially, then stops ...
 in
Dryer Repair
Well, my case sounds exactly like the May 5, 2009 blog posting. Here's what's happened: Tech diagnosed the problem as
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heats up initially, then stops ...
  #1 (permalink)
Old 07-16-2009, 01:53 PM
Junior Member
Avenger9 is on a distinguished road
Default Heats up initially, then stops ...
Model Number: GLEQ2152ES0   Brand: Frigidaire   Age: 1 - 5 years
Tech diagnosed the problem as the control board. Everything else is good, he says. It'll be 2 weeks and $225 for the board, according to him. 2 weeks!?! That's just not possible, so I order the part myself on-line for $75 less and have it next day. He comes back to install the new board.....uh oh, that doesn't seem to fix the problem. He's scratching his head, taking the whole thing apart now to re-check things. He says "it's another bad board....I don't know what else to tell you, it HAS to be the board" WTF?! C'mon, what are the chances of getting a bad board.
I call the place where I ordered the board, describe the situation, the guy (who happens to be a tech himself) says, "did he check the thermistor?" I ask the guy, and supposedly it's OK. Another question from the guy on the phone -- Is there 240v at the relay on the board when the dryer is on? Answer is yes. Guy on the phone insists then that the board is fine, the thermistor is the problem.
I also notice the tech used a jumper on the relay and the heating element came to life (just as you describe in the blog). But still, in his mind, something on the board is bad and is affecting the relay. At least, this is what he claims. (In the back of his mind, I think he's realizing he mis-diagnosed....)
He's going to order a thermistor and try that tomorrow, just to be sure. But he still says 99.9% it's the board. Uh huh...
So, any other thoughts..... is this a textbook thermistor problem? And really, what are the chances of getting a bad board? I know, very slim...and I'm extremely skeptical. That being the case, it looks like I'm gonna be stuck with this control board, should it not be the culprit. Thanks in advance
Ads By Google
Related Models
Frigidaire GLEQ2152ES0 Frigidaire/dryer
Frigidaire GLEQ221AS2 Frigidaire/electric Dryer
Frigidaire GLEQ332AS0 Dryer - Frig Gallery
Frigidaire GLEQ332AS1 Dryer - Frig Gallery
Frigidaire GLEQ332AS2 Frigidaire/electric Dryer
Frigidaire GLEQ442CES0 Frigidaire/electric Dryer
Frigidaire GLEQ642AS0 Dryer - Frig Gallery
Frigidaire GLEQ642AS1 Dryer - Frig Gallery
Frigidaire GLEQ642AS2 Frigidaire/electric Dryer
Frigidaire GLEQ942CS0 Frigidaire/dryer
Frigidaire GLER1042FC0 Frigidaire/dryer
Frigidaire GLER1042FS0 Frigidaire/dryer
Frigidaire GLER104FSS0 Frigidaire/dryer
Frigidaire GLER331AQ1 Dryer - Frigidaire Gallery
Frigidaire GLER331AQ2 Frigidaire/dryer
Frigidaire GLER331AS0 Dryer - Frig Gal
Frigidaire GLER331AS1 Dryer - Frigidaire Gallery
Frigidaire GLER331AS2 Frigidaire/dryer
Frigidaire GLER341AS0 Dryer - Frigidaire Gallery
Frigidaire GLER341AS1 Dryer - Frigidaire Gallery
Frigidaire GLER341AS2 Frigidaire/electric Dryer
Frigidaire GLER341CC0 Frigidaire/dryer
Frigidaire GLER341CDC0 Frigidaire/dryer
Frigidaire GLER341CES0 Frigidaire/dryer
Whirlpool GLER5434BN0
Whirlpool GLER5434BN1
Whirlpool GLER5434BQ1
Whirlpool GLER5434BW0
Whirlpool GLER5434BW1
Frigidaire GLER642AS0 Dryer - Frigidaire Gallery
Frigidaire GLER642AS1 Dryer - Frigidaire Gallery
Frigidaire GLER642AS2 Dryer - Frig Gallery
Frigidaire GLER642AS3 Frigidaire/dryer
Frigidaire GLES388ASA Frigidaire/electric Range
Frigidaire GLES388ASB Frigidaire/electric Range
Frigidaire GLES388ASC Frigidaire/electric Range
Frigidaire GLES388ASD Frigidaire/electric Range
Frigidaire GLES388ASE Frigidaire/electric Range
Frigidaire GLES388CSA Frigidaire/electric Range
Frigidaire GLES388CSB Frigidaire/electric Range
Frigidaire GLES388DBA Frigidaire/electric Range
Frigidaire GLES388DBB Frigidaire/electric Range
Frigidaire GLES388DQA Frigidaire/electric Range
Frigidaire GLES388DQB Frigidaire/electric Range
Frigidaire GLES388DSA Frigidaire/electric Range
Frigidaire GLES388DSB Frigidaire/electric Range
Frigidaire GLES389EBA Frigidaire/electric Range
Frigidaire GLES389EBB Frigidaire/electric Range
Frigidaire GLES389EBC Frigidaire/electric Range
Frigidaire GLES389EBD Frigidaire/electric Range
Frigidaire GLES389EBE Frigidaire/electric Range
Frigidaire GLES389EQA Frigidaire/electric Range
Frigidaire GLES389EQB Frigidaire/electric Range
Frigidaire GLES389EQC Frigidaire/electric Range
Frigidaire GLES389EQD Frigidaire/electric Range
Frigidaire GLES389EQE Frigidaire/electric Range
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC30S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSB Frigidaire/gas Cooktop
Frigidaire GLGC30S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S9ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASA Frigidaire/gas Cooktop
  #2 (permalink)
Old 07-17-2009, 04:50 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Avenger
You don't give us a lot to go on, just a short phrase about what is wrong with your dryer, so it is difficult to give you a whole lot of help.
Your problem does sound like a thermistor, but it can be the board also.
Here is the service manual, with all sorts of troubleshooting methods.
http://frigidaireservicetips.com/pdf...isWasherSM.pdf
See if you can narrow it down,
Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite H3 - Heats up initially but then stops heating. anonymouscuban Dryer Repair 2 01-07-2010 07:52 PM
GE Gas Dryer heats initially and then goes cool Greggy_D Dryer Repair 1 12-29-2009 11:43 AM
Dryer heats up then stops heating Art C. Little Dryer Repair 0 04-24-2009 06:17 AM
Heats once then stops jiraci Dryer Repair 1 02-26-2009 05:31 AM
Heats once and stops vmac Dryer Repair 1 07-22-2008 03:34 PM
