debusk
#1 Posted : Sunday, January 29, 2012 9:52:11 AM(UTC)
debusk
I need help on tseting my start switch with a digital ohmmeter. I don't think it is working but I need to confirm I am doing it right.
ApplianceJunk
#2 Posted : Sunday, January 29, 2012 9:55:51 AM(UTC)
ApplianceJunk
The way I would test the start switch with a multimeter is to check the switch for continuity.
I can tell you from experience though that it's never the start switch that is the problem. :)
If the dryer does not start at all I would check the thermal fuse on the back of the dryer. If the dryer does not start, but you can hear the motor humming like it's trying to start then the motor is probably at fault and needs to be replaced.
Just my 2 cents...
GE Dryer turning on without using start switch (Dryer Repair)
by Sinanan 8/15/2015 8:28:21 PM(UTC)
Dryer and buzzer won't stop, start switch is ok (Dryer Repair)
by Thorzdad 7/12/2015 12:04:26 PM(UTC)
All LEDs out, only the start switch works (Dishwasher Repair)
by Jimbo Bigbelly 2/11/2015 11:55:12 AM(UTC)
Dryer start switch wiring (Dryer Repair)
by canifixit14 9/5/2014 6:23:39 AM(UTC)
Maytag dryer will not stay running unless you hold the start switch (Dryer Repair)
by J-Bird-Medic 8/28/2014 7:53:06 AM(UTC)
by duckb0y01 3/15/2014 10:11:53 AM(UTC)
Dryer starts w/o start switch (Dryer Repair)
by jhasr 1/28/2014 5:43:38 AM(UTC)
Replace dryer start switch (Dryer Repair)
by Jpcboca 2/25/2013 7:52:09 AM(UTC)
Dryer runs (without heat) only by holding down Push-to-Start switch. (Oven Repair (including Ranges and Cooktops))
by Reinaldo 12/18/2012 7:51:00 PM(UTC)
Dryer start switch won't stay on. (Dryer Repair)
by liebem 9/16/2012 6:06:38 PM(UTC)
Testing Start Switch Continuity- Which Prongs? (Dryer Repair)
by socrjul 5/25/2012 8:17:24 AM(UTC)
Dryer will not start. Need help with 3 terminal start switch (Dryer Repair)
by EDogzz 5/17/2012 6:38:26 PM(UTC)
Rotary Start Switch (Dryer Repair)
by pdl2 4/23/2012 4:46:54 AM(UTC)
Must continue to hold start switch to operate dryer (Dryer Repair)
by ABCh 4/1/2012 8:38:31 PM(UTC)
Dryer start switch won't hold (Dryer Repair)
by carl Quinto 7/23/2011 12:07:40 PM(UTC)
