Discuss
Electric Dryer Not Heating
 in
Dryer Repair
Got a call yesterday from a guest stating the dryer in their vacation condo was not heating properly. My maintenance
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric Dryer Not Heating
  #1 (permalink)
Old 07-16-2009, 11:33 AM
Junior Member
Global Kiss is on a distinguished road
Question Electric Dryer Not Heating
Brand: Whirlpool   Age: 5 - 10 years
Got a call yesterday from a guest stating the dryer in their vacation condo was not heating properly. My maintenance tech cleaned the exhaust/vent lines from the dryer to the roof as this has been a consistent problem at this particular complex (first time in this condo though). That did not solve the problem.
He ran the dryer while watching the heating coils and they burn red hot for anywhere from 4 to 10 minutes at a time, and then will shut off.
He thinks some sort of sensor somewhere may be going bad ... do you have any ideas?
Your insight and suggestions are appreciated.
KL
Ads By Google
  #2 (permalink)
Old 07-16-2009, 07:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the model number of the dryer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-20-2009, 09:26 AM
Junior Member
Default Model #
Thank you Gene - sorry for the delay, had to wait on maintenance to get the info for me and I am not in the office on weekends.
According to maintenance notes, it is Whirlpool Model #LER4634EQ2 ... Serial #MJ4338281 ... "type" D433-ELE-2406028-FM54
  #4 (permalink)
Old 07-20-2009, 11:51 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is remove the rear panel, remove the lint chute (#1 on the diagram) and make sure it's clean and the blower wheel is fine. Then replace the cycling thermostat (#24).
- The cycling thermostat Part number: AP3131939
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4634EQ2 | AppliancePartsPros.com
__________________
  #5 (permalink)
Old 07-20-2009, 11:57 AM
Junior Member
Default
Thank you Gene, I will give this information to my maintenance tech and let you know what he comes back with.
  #6 (permalink)
Old 07-23-2009, 01:46 PM
Junior Member
Default
Gene,
Ordered the part and maintenance has replaced it ... appears to have solved the problem.
He did want me to ask you however, if it is normal that the heating element glows red hot for 20 to 25 seconds, then stops glowing for about 1 minute, then glows 20 to 25 seconds, then stops glowing, etc. This continues throughout the cycle.
He is guessing this is how the heater operates, not glowing red hot through the entire cycle to prevent it from getting too hot.
Is this normal?
  #7 (permalink)
Old 07-23-2009, 02:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad to hear it's back in business.
Yes, the heating element should cycle on and off to maintain the proper temperature inside the dryer which controls by the cycling thermostat.
Good luck with your dryer.
__________________
  #8 (permalink)
Old 07-23-2009, 02:16 PM
Junior Member
Default
Gene,
I will relay the information to him. Thank you so much for your help. I know we'll be back!
I just can not say enough about Appliance Parts Pros - I use APP for work and when I need something at my personal home.
The prices, shipping times, live chat, and forum are just incredible.
Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric Dryer not heating RJ Trucks Dryer Repair 8 09-09-2010 08:58 AM
Electric Dryer not heating glopez01 Dryer Repair 1 12-07-2009 03:59 PM
Electric Dryer Not Heating bkeiger Oven Repair (including Ranges and Cooktops) 3 08-01-2009 07:56 AM
electric dryer not heating up ltrain Dryer Repair 1 01-12-2009 05:39 AM
Electric Dryer Not Heating doutre Dryer Repair 3 09-30-2008 07:53 PM
