I was told if you take back of dryer off and get to PTS switch you pull the two wires off and join them together and turn timer from off to set time the dryer should run if it is just a bad push to start switch. After taking back off there are 4 wires, 2 black 1 green and 1striped wires. I don't know which wires to join together to make the dryer run if this is possible. Will this tell me if I have a bad push to start switch and which 2 wires do you join together to perform this test? Thank you
