Discuss
Kenmore runs but won't heat
 in
Dryer Repair
My dryer quit heating 4 days ago. 5 kids and right before school started today when I need it most.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore runs but won't heat
  #1 (permalink)
Old 08-08-2007, 10:48 AM
kbarr kbarr is offline
Junior Member
kbarr is on a distinguished road
Default Kenmore runs but won't heat
Model Number: 110.86873100 68731   Brand: Kenmore   Age: More than 10 years
My dryer quit heating 4 days ago. 5 kids and right before school started today when I need it most. I am assuming it's the heating element, but that's just a guess. This dryer is 16 years old and the 1st I've ever had a problem with it. Can someone tell me where to begin, how I can find the part, can I order the part and install it myself? All help is appreciated.
Related Models
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
  #2 (permalink)
Old 08-08-2007, 11:12 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
kbarr
The first thing I would do is to check the heat element. Pull the dryer out of the wall, remove the power, remove the rear cover. On the right side you'll see the heater box. Remove wires from the heater and check it for continuity. If there is no continuity then the heater has to be replaced. The part number for the new heater is AP3109438
If the heater is fine check the thermal fuse and the thermal cut off. Part number for the thermal fuse is AP3132867 and the part number for the thermal cut off is AP3094224
Good luck.
  #3 (permalink)
Old 08-09-2007, 05:26 PM
Junior Member
Default Thank you
I will check that out tonight. Thank you for supplying part numbers.
  #4 (permalink)
Old 09-11-2009, 10:26 AM
tlksr98 tlksr98 is offline
Junior Member
tlksr98 is on a distinguished road
Default Same dryer problem
Kbarr
I have the same dryer and the same problem your were having how did you get it fixed.
Terry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer has no heat but runs Ron L. Dryer Repair 7 06-15-2009 12:12 PM
Dryer runs but doesn't heat Jane Dryer Repair 6 08-07-2007 10:01 PM
Runs no Heat. hucksplace Dryer Repair 0 08-02-2007 05:03 PM
Dryer runs no heat Wesley Dryer Repair 3 07-28-2007 12:23 AM
