Discuss
Dryer not working
 in
Dryer Repair
My dryer is a GE Estate dryer by Whirlpool. It will turn on and get hot, but the drum won't
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer not working
  #1 (permalink)
Old 07-15-2009, 12:07 PM
Junior Member
jmccall93 is on a distinguished road
Default Dryer not working
Model Number: TEDS840PQ0   Brand: Whirlpool   Age: 1 - 5 years
My dryer is a GE Estate dryer by Whirlpool. It will turn on and get hot, but the drum won't turn, and the dryer makes no noises sounding like it is attempting to start no matter the cycle I try to put it in. Please help! This dryer is not that old (3 years maybe) and we've already had a heating coil problem in it the first year that we were able to replace.
Thanks,
Jill
Related Models
 TEDS840PQ0 29"ELECTRIC DRYER
 TEDS840PQ1 29"ELECTRIC DRYER
 TEDX340RW0 29" ELECTRIC DRYER
 TEDX340RW1 29" ELECTRIC DRYER
 TEDX340RW2 29" ELECTRIC DRYER
Whirlpool TEDX540RQ0 29" ELECTRIC DRYER
 TEDX540RQ1 29" ELECTRIC DRYER
 TEDX640EQ0 ELECTRIC DRYER
 TEDX640EQ1 DRYERS
 TEDX640EQ2 ELECTRIC DRYER
 TEDX640JQ0 ELECTRIC DRYER
 TEDX640JQ1 DRYER
 TEDX640JQ2 29"ELECTRIC DRYER
 TEDX640PQ0 29" ELECTRIC DRYER
 TEDX640PQ1 29"ELECTRIC DRYER
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BU4 ELECTRIC RANGE
Tappan TEF242BU5 ELECTRIC RANGE
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF242BW4 ELECTRIC RANGE
Tappan TEF242BW5 ELECTRIC RANGE
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF303BWF RANGE
Tappan TEF303BWG RANGE
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Tappan TEF317BWF ELECTRIC RANGE
Tappan TEF317BWG ELECTRIC RANGE
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FBB ELECTRIC RANGE
Tappan TEF326FBC ELECTRIC RANGE
Tappan TEF326FSA Tappan/range
Tappan TEF326FSB ELECTRIC RANGE
Tappan TEF326FSC ELECTRIC RANGE
Tappan TEF326FSD ELECTRIC RANGE
Tappan TEF326FSE ELECTRIC RANGE
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Tappan TEF351EWD ELECTRIC RANGE
Tappan TEF351EWE ELECTRIC RANGE
Tappan TEF351EWF ELECTRIC RANGE
Tappan TEF351EWG ELECTRIC RANGE
Tappan TEF351EWH ELECTRIC RANGE
Tappan TEF351EWJ TAPPAN/ELECTRIC RANGE
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
  #2 (permalink)
Old 07-16-2009, 04:54 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Jmccal
This is not supposed to happen, your dryer should not allow the heating element to come on unless the motor is running and the dryer is turning.
You need to determine if the problem is the belt or the motor.
Take out the two screws under the lint filter lid, and then pop up the top from the front.
If you belt is ok, you need to try and start the dryer and see if the motor is operating. If it is, the drum may be hung up in some way, but more likely the problem is in the motor.
Good luck, let us know what you find out.
__________________
  #3 (permalink)
Old 07-16-2009, 07:57 PM
Junior Member
Default
We took the top off, and there's appears to be nothing wrong with the belt when we turn the drum manually to look at it. When we start the dryer absolutely nothing happens. No sounds - no click other than that of the start button being pushed in. We might as well have it unplugged except that you can see and feel the heating element heat up.
  #4 (permalink)
Old 07-16-2009, 08:09 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Did you check to see if the breaker was partially tripped?
  #5 (permalink)
Old 07-16-2009, 09:47 PM
Junior Member
Default
No we haven't. But if that was the case I don't think the heating element would be working either and it heats up just fine even though the dryer would turn the drum or actually start the cycle.
Jill
  #6 (permalink)
Old 07-16-2009, 09:48 PM
Junior Member
Default
Sorry. Even though the "dryer WON'T turn the drum or ...".
Jill
  #7 (permalink)
Old 07-17-2009, 06:11 AM
Senior Expert
APP Volunteer
Default
Hi Jill
Sorry you have had trouble with this machine, it is usually one of the more reliable products.
If your drum turns and the belt is not broken the problem is that your motor is not turning the drum. What worries me is that the heat is coming on. As a safety feature this is not supposed to happen if the motor has not come on and turning the drum.
The likely problem is that there is a problem in your motor wiring, in which case the motor will have to be replaced. First remove the drum and make certain everything looks ok, particularly the wiring and if so a new motor may solve your problem.
Good luck, hope that fixes it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not working VKBUTANI Dryer Repair 1 01-13-2010 07:22 AM
dryer not working row128@yahoo.com Dryer Repair 0 08-28-2009 11:23 AM
dryer not working right Ferrell2008 Dryer Repair 0 06-07-2009 09:50 AM
Dryer Not Working pigoo3 Dryer Repair 3 10-18-2007 03:04 AM
dryer not working lawndude Dryer Repair 1 10-05-2007 02:35 PM
