Danielwolfmountain
#1 Posted : Monday, January 23, 2012 1:52:16 PM(UTC)
Danielwolfmountain
I have a Kenmore dryer model #: 417.93042201 My dryer is not drying clothes. It has good air flow and I believe the problem is with the heat. It will start the burner and heat up at the beginning of the cycle but it seems the farther the cycle goes the less the burner will come on. Therefore, the clothes end up wet at the end of the cycle. I have tried the auto dry and the time dry setting and neither one will dry clothes. I also observed the igniter as it cycled on and off later in the cycle. About every 30sec the igniter would pull 3.2 to 3.4 amps. It would light up for about 5 to 10 sec then go dark and it would stop drawing power. About every 5th or so time of lighting up and going dark the gas would ignite and heat up the dryer. I think it may be either the igniter or the gas valve that is the problem but because it is working some of the time I'm not really sure?
Jerry L. Dunnahoo
#2 Posted : Monday, January 23, 2012 6:54:07 PM(UTC)
Jerry L. Dunnahoo
Groups: Expert
Sounds like the gas valve coils are getting weak. Most probable cause of this complaint would be part number AP2150379. Everytime I've heard the complaint that the unit gets cooler with each cycling of the ignitor, this has solved the problem. Let me know if I can help anymore! =]
Danielwolfmountain
#3 Posted : Tuesday, January 24, 2012 8:55:10 AM(UTC)
Danielwolfmountain
Thank you for the quick reply. I will order that part and give it a try.
