Discuss
Kenmore dryer
 in
Dryer Repair
I have a Kenmore dryer and it will not stay running and does not heat up. I can press the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer
  #1 (permalink)
Old 01-21-2012, 09:40 PM
Junior Member
fletch503 is on a distinguished road
Default Kenmore dryer
Model Number: 11063952101   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore dryer and it will not stay running and does not heat up. I can press the "push to start" switch and it starts; but as soon as presssure is released from the switch it turns off.
I tested the breaker at the panel and found it to be working. Next I tested (with a multi-meter) the power outlet and found that it appeared to be within required parameters. Next I tested the push to start switch. Removing the contacts and testing with a multimeter while pushing the button. I got a tone from my meter. I think the switch is good.
Then I disassembled the unit and tested continuity of the heat element, the high limit cut-off and the thermal cut-off. All of these appeared to have good continuity (my multimeter emitted a tone upon contact). Next I removed the heating element and check for any breaks in the element, none were found. There was some discoloration and a few hairline cracks on the metal plattform upon which the element is intertwined. I assume these are normal.
Next I moved on to test the thermal fuse and the thermistor, both of these are located on the blower housing. I disconnected one of the contacts on each and got a good reading on the thermal fuse; however the thermistor gave no tone when I tested it.
I have never posted to a forum so I apoligize if my posting is to lengthy. FINALLY my question; I want to know if the thermistor is the problem as it failed the continuity test. Any help in this matter would be greatly helpful. Thanks for your time and feedback.
Ads By Google
Related Models
Kenmore 1106407400 KENMORE GAS DRYER
Kenmore 1106407401 GAS DRYER
Kenmore 1106407500 KENMORE GAS DRYER
Kenmore 1106407501 KENMORE GAS DRYER
Kenmore 1106407502 KENMORE GAS DRYER
Kenmore 1106407540 KENMORE GAS DRYER
Kenmore 1106407700 KENMORE GAS DRYER
Kenmore 1106407701 KENMORE GAS DRYER
Kenmore 1106407702 KENMORE GAS DRYER
Kenmore 1106407740 KENMORE GAS DRYER
Kenmore 1106407741 KENMORE GAS DRYER-NOVEMBER, 1964
Kenmore 1106407800 KENMORE GAS DRYER
Kenmore 1106407801 KENMORE GAS DRYER
Kenmore 1106407840 KENMORE GAS DRYER
Kenmore 1106407841 KENMORE GAS DRYER
Kenmore 1106407900 KENMORE GAS DRYER
Kenmore 1106407901 KENMORE GAS DRYER
Kenmore 1106407902 KENMORE GAS DRYER
Kenmore 1106407920 KENMORE GAS DRYER
Kenmore 1106407922 KENMORE GAS DRYER
Kenmore 1106407930 KENMORE GAS DRYER
Kenmore 1106407931 KENMORE GAS DRYER
Kenmore 11064082200 ELECTRIC DRYER
Kenmore 11064082201 ELECTRIC DRYER
Kenmore 1106408400 KENMORE ELECTRIC DRYER
Kenmore 1106408401 KENMORE ELECTRIC DRYER
Kenmore 11064084200 ELECTRIC DRYER
Kenmore 11064084201 ELECTRIC DRYER
Kenmore 1106408500 KENMORE ELECTRIC DRYER
Kenmore 1106408501 KENMORE ELECTRIC DRYER
Kenmore 1106408540 KENMORE ELECTRIC DRYER
Kenmore 11064086200 ELECTRIC DRYER
Kenmore 11064086201 ELECTRIC DRYER
Kenmore 1106408700 KENMORE ELECTRIC DRYER
Kenmore 1106408701 KENMORE ELECTRIC DRYER
Kenmore 1106408740 KENMORE ELECTRIC DRYER
Kenmore 1106408741 KENMORE ELECTRIC DRYER
Kenmore 1106408800 KENMORE ELECTRIC DRYER
Kenmore 1106408801 KENMORE ELECTRIC DRYER
Kenmore 1106408840 KENMORE ELECTRIC DRYER
Kenmore 1106408841 KENMORE ELECTRIC DRYER
Kenmore 1106408900 GAS DRYER
Kenmore 1106408901 KENMORE ELECTRIC DRYER
Kenmore 1106408902 KENMORE ELECTRIC DRYER
Kenmore 1106408920 KENMORE ELECTRIC DRYER
Kenmore 1106408922 KENMORE ELECTRIC DRYER
Kenmore 1106408930 KENMORE ELECTRIC DRYER
Kenmore 1106507400 KENMORE GAS DRYER
Kenmore 1106507500 KENMORE GAS DRYER
Kenmore 1106507700 KENMORE GAS DRYER
Kenmore 1106507800 KENMORE GAS DRYER
Kenmore 1106507801 KENMORE GAS DRYER
Kenmore 1106507802 KENMORE GAS DRYER
Kenmore 1106507810 KENMORE GAS DRYER
Kenmore 1106507820 KENMORE GAS DRYER
Kenmore 1106507821 KENMORE GAS DRYER
Kenmore 1106507822 KENMORE GAS DRYER
Kenmore 1106507823 KENMORE GAS DRYER
Kenmore 1106507825 KENMORE GAS DRYER
Kenmore 1106507830 KENMORE GAS DRYER
Kenmore 1106507831 KENMORE GAS DRYER
Kenmore 1106507920 KENMORE GAS DRYER
Kenmore 1106507921 KENMORE GAS DRYER
Kenmore 1106507923 KENMORE GAS DRYER
Kenmore 1106507930 KENMORE GAS DRYER
Kenmore 1106507933 KENMORE GAS DRYER
Kenmore 1106507934 KENMORE GAS DRYER
Kenmore 1106507935 KENMORE GAS DRYER
Kenmore 1106507940 KENMORE GAS DRYER
Kenmore 1106507941 KENMORE GAS DRYER
Kenmore 1106508400 KENMORE ELECTRIC DRYER
Kenmore 1106508500 KENMORE ELECTRIC DRYER
Kenmore 1106508700 KENMORE ELECTRIC DRYER
Kenmore 1106508800 KENMORE ELECTRIC DRYER
Kenmore 1106508801 KENMORE ELECTRIC DRYER
Kenmore 1106508802 KENMORE ELECTRIC DRYER
Kenmore 1106508810 KENMORE ELECTRIC DRYER
Kenmore 1106508811 KENMORE ELECTRIC DRYER
Kenmore 1106508820 KENMORE ELECTRIC DRYER
Kenmore 1106508821 KENMORE ELECTRIC DRYER
Kenmore 1106508822 KENMORE ELECTRIC DRYER
Kenmore 1106508921 KENMORE ELECTRIC DRYER
Kenmore 1106508922 KENMORE ELECTRIC DRYER
Kenmore 1106508923 KENMORE ELECTRIC DRYER
Kenmore 1106508930 KENMORE ELECTRIC DRYER
Kenmore 1106508933 KENMORE ELECTRIC DRYER
Kenmore 1106508934 KENMORE ELECTRIC DRYER
Kenmore 1106508935 KENMORE ELECTRIC DRYER
Kenmore 1106508940 KENMORE ELECTRIC DRYER
Kenmore 1106517400 KENMORE GAS DRYER
Kenmore 1106517401 KENMORE GAS DRYER
Kenmore 1106517402 KENMORE GAS DRYER
Kenmore 1106517500 KENMORE GAS DRYER
Kenmore 1106517501 KENMORE GAS DRYER
Kenmore 1106517502 KENMORE GAS DRYER
Kenmore 1106517510 KENMORE GAS DRYER
Kenmore 1106607400 KENMORE GAS DRYER
Kenmore 1106607401 KENMORE GAS DRYER
Kenmore 1106607410 KENMORE GAS DRYER
Kenmore 1106607500 KENMORE GAS DRYER
Kenmore 1106607501 KENMORE GAS DRYER
Kenmore 1106607600 KENMORE GAS DRYER
Kenmore 1106607601 KENMORE GAS DRYER
Kenmore 1106607700 KENMORE GAS DRYER
Kenmore 1106607701 KENMORE GAS DRYER
Kenmore 1106607710 KENMORE GAS DRYER
Kenmore 1106607711 KENMORE GAS DRYER
Kenmore 1106607800 KENMORE GAS DRYER
Kenmore 1106607801 KENMORE GAS DRYER
Kenmore 1106607802 KENMORE GAS DRYER
Kenmore 1106607810 KENMORE GAS DRYER
Kenmore 1106607900 KENMORE GAS DRYER
Kenmore 1106607910 KENMORE GAS DRYER
Kenmore 1106607911 KENMORE GAS DRYER
Kenmore 1106607920 KENMORE GAS DRYER
Kenmore 1106607921 KENMORE GAS DRYER
Kenmore 1106607930 KENMORE GAS DRYER
Kenmore 1106607931 KENMORE GAS DRYER
Kenmore 1106607940 KENMORE GAS DRYER
Kenmore 1106608400 KENMORE ELECTRIC DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 Series Dryer, timer does not stop dryer rjoshuaw Dryer Repair 1 03-08-2012 06:38 AM
Kenmore Elite Washer and Dryer. Dryer model # 11060096991 fburr4054 Dryer Repair 1 11-21-2011 06:12 AM
Kenmore Washer/Dryer Combo Dryer won't stay on Jmasters Dryer Repair 0 09-06-2011 10:49 AM
Kenmore Washer+Dryer, Dryer not working Sgat8516 Dryer Repair 11 03-29-2011 03:10 PM
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off poslow Dryer Repair 2 11-21-2010 10:10 PM
