| » Maytag electric dryer wont stay running |
Model Number: pdet910ayw Brand: Maytag Age: 1 - 5 years
I replaced today the air duct by the tumbler. It was broken. I put everything together and it worked fine. I came home an hour later and my wife said the dryer will not stay running. It only runs if you hold in the start button. I have unplugged for 10 minutes hoping for somekind of reset. No lUCK. Please Help.. Thanks George
Hi George
This problem is usually associated with a failure of the motor wiring. I would take the machine apart again and make sure you have good wiring connections to the motor. If that does not fix it, you might want to change the timer out, as it is not expensive, but I fear that a motor replacement may be the solution. Good luck
__________________
Hi George
Good question. Dryer motors generally have two sets of windings, start and run. If there is a problem in the wiring the dryer will shut off unless you hold in the start switch. That is why I suggested you thoroughly check the connections to the motor. If you want to you can change out the start switch and see if that cures your problem. Sometimes that is where the problem is.
__________________
| Display Modes | |
| GE Electric Dryer won't stay running | bdrg | Dryer Repair | 2 | 10-31-2010 09:32 AM |
| electric dryer will not stay running | jerry aiello | Dryer Repair | 1 | 10-16-2009 09:07 AM |
| Electric dryer will stay running or heat up | AnnieB. | Dryer Repair | 1 | 05-21-2009 05:51 PM |
| Dryer wont stay running | TPost | Dryer Repair | 1 | 02-22-2009 03:24 AM |
| Kenmore gas dryer wont stay running | kthomas | Dryer Repair | 0 | 02-12-2008 12:57 PM |
