Discuss
Dryer will no heat up
 in
Dryer Repair
Hi there. Thank you for all the help that you provide. I need some help. My Whirlpool dryer is no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will no heat up
  #1 (permalink)
Old 01-17-2012, 08:33 AM
Junior Member
Onlyloco is on a distinguished road
Default Dryer will no heat up
Brand: Whirlpool   Age: 1 - 5 years
Hi there. Thank you for all the help that you provide. I need some help. My Whirlpool dryer is no longer Heating up, everything else works fine. The hi-limit thermostat is open so I need a new one. The part # is 3399848. Could you tell me where I find this part on your website? Second question is what else should I check?
Hi temp thermostat (3399848)is open
Thermal fuse (3399693 ... Is this the correct part?) seems fine
Cycling thermostat I couldn't find.
Model number is LER3624EQ1
Thank you
  #2 (permalink)
Old 01-17-2012, 02:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The hi-limit thermostat is shown as #15 on the diagram. It comes as a part of the kit including the thermal cut-off thermostat (#6). The cycling thermostat is shown as #24 on the same diagram.
- The thermal cut-off kit Part number: AP3094244
Here are the breakdown diagrams and http://www.appliancepartspros.com/pa...odel_id=246745
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-17-2012, 03:25 PM
Junior Member
Default
Got it! Thank you for your help!
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER3624EQ1 ELECTRIC DRYER | AppliancePartsPros.com
  #4 (permalink)
Old 01-17-2012, 06:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #5 (permalink)
Old 01-29-2012, 05:56 PM
Junior Member
Default
Thank you Gene. I bought those parts and also some parts I needed for my refrigerator. My issue is fixed. Thank you so much for your help. Your service is amazing and shipping is lighting fast!
  #6 (permalink)
Old 02-02-2012, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
