timros
#1 Posted : Monday, January 16, 2012 2:06:15 PM(UTC)
timros
Maytag front load dryer, MED5800TW0, will not tumble. Heating element works, but won't tumble. I took it apart expecting to see a broken belt. It was intact. I replaced the belt anyway thinking it might just be stretched and loose. That did not fix the problem Thermal cutoff going to fix it? Thanks.
#2 Posted : Monday, January 16, 2012 5:03:38 PM(UTC)
Does the motor run?
timros
#3 Posted : Monday, January 16, 2012 8:58:13 PM(UTC)
timros
When I push the start button, nothing happens. You can feel the heating element is working, because it gets hot in the drum. However, there is no sound or movement at all.
#4 Posted : Monday, January 16, 2012 9:20:27 PM(UTC)
Very likely the problem is a bad motor centrifugal switch. The heating element should not go On if the motor is not running. The correction is to replace the motor.
- The motor Part number: AP3094245
