Discuss
Intermittent heat
 in
Dryer Repair
Dryer would not heat. Every time I replace a part it works fine for a few loads then stops heating
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Intermittent heat
  #1 (permalink)
Old 07-13-2009, 07:37 AM
Junior Member
fxn001 is on a distinguished road
Default Intermittent heat
Brand: Whirlpool   Age: 5 - 10 years
Dryer would not heat. Every time I replace a part it works fine for a few loads then stops heating again.
I replaced the thermal fuse - watched the igniter glow and light the gas. Put it all back together, ran two loads fine then it stopped heating.
Replaced the thermostat (the one on the heater box). Watched the igniter glow and light the gas. Put it all back together, ran two more loads and then it stopped heating.
Opened the back again and noticed the connector to the newly replaced thermostat was loose. I tighted it up, watched the igniter glow and light the gas. Put it all back together, ran a load fine and then it stopped heating again.
What should I look at next?
Ads By Google
  #2 (permalink)
Old 07-13-2009, 01:18 PM
Junior Member
Prof. Maneuver is on a distinguished road
Default
Sir-
How about airflow obstructions everywhere including the exhaust obviously, then jumper around the T-stats/T-fuse one at a time and see if it lights, failing that, flame sensor? Not really sure how that works, could be hazardous to defeat!
Good Luck to You,
Steve
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Intermittent Problem w/ Heat rjl41 Dryer Repair 0 12-09-2009 04:48 PM
Intermittent Heat docsaintly Dryer Repair 1 07-31-2009 09:49 AM
Dryer intermittent to no heat edm812 Dryer Repair 6 07-30-2009 07:03 PM
Intermittent dryer heat edm812 Dryer Repair 4 04-15-2009 06:08 AM
Intermittent Heat ASinSeattle Dryer Repair 0 12-22-2008 08:20 PM
