| » dryer element not coming on |
Model Number: 110.66522500 Brand: Kenmore Age: 1 - 5 years
I have replaced the dryer element and the element isn't coming on. What other parts would I need to purchase to make the dryer element come on.
thanks smiley Ads By Google Related Models |
There are two thermostats on the heater-can that will cause this and go bad more often then the heater. You should check them for continuity with an ohmmeter because they are not necessary the problem. Check you vent because poor airflow can cause this the thermostats to go bad. Hope this helps! Clothes Dryer Repair Guide
| Display Modes | |
| dryer wont get hot, new element & therm on element | Thomas Bronte | Dryer Repair | 1 | 11-20-2009 07:48 PM |
| dryer door coming open | pjrebel3 | Dryer Repair | 1 | 10-28-2009 02:04 PM |
| dryer works but no heat coming out | villanuevanc | Dryer Repair | 1 | 03-16-2009 04:38 AM |
| Element won't heat up (20ohms on element and 120volts to the element)? | puddlejumper123 | Oven Repair (including Ranges and Cooktops) | 0 | 04-22-2008 07:49 PM |
| no heat coming from dryer | chrisnross | Dryer Repair | 0 | 09-04-2007 07:36 PM |
