Discuss
Squeeling sound
 in
Dryer Repair
Whenever I turn my dryer on it starts to make a loud squeeling sound and last until I turn my
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Squeeling sound
  #1 (permalink)
Old 07-12-2009, 02:00 PM
Junior Member
mathew is on a distinguished road
Default Squeeling sound
Model Number: LNC8757A71   Brand: Admiral   Age: More than 10 years
Whenever I turn my dryer on it starts to make a loud squeeling sound and last until I turn my dryer off. The drum turns fine, the heat is fine. What can I look for in repairing this horrible noice?
Ads By Google
Related Models
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
  #2 (permalink)
Old 07-14-2009, 04:24 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Mathew
I cannot get your model to come up, but your noise is likely from the drum.
Take off the top and try to turn the drum manually to hear where the noise is coming from. It is likely from the back where the drum is supported.
__________________
  #3 (permalink)
Old 07-14-2009, 05:34 PM
Junior Member
Default squeeling
yes, I already took the top off and did spin the drum manually and the noise is coming from the back. This is where I get stuck, I don't know what to check or replace after that..thanks
  #4 (permalink)
Old 07-15-2009, 06:10 AM
Senior Expert
APP Volunteer
Default
Hi Mathew
Ok, glad you have the area of the noise.
I cannot get anything to come up on your model, so I am going to have to give you some general advice.
You need to take out the drum and change out the rear support, which are probably rollers of some type or the tensioner if that turn out to be the problem. To do this you need to release the belt, which can be done by releasing tension on the tensioner. You may be able to access this from the front, but more likely there is a service panel in the back which will come off to get to it.
Take off the front and then you should be able to remove the drum and see the parts that need to be replaced.
Good luck, let us know what you find.
__________________
  #5 (permalink)
Old 07-15-2009, 05:33 PM
Junior Member
Default squeeling
ok, thanks..i'm going to work on it this weekend and i'll let you know
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Squeeling Dryer darla4257 Dryer Repair 1 11-19-2009 07:06 PM
Squeeling drum rollers teerlirs Dryer Repair 1 05-08-2009 02:13 PM
Whirlpool washer LOUD Squeeling! js1268 Washer Repair 3 10-19-2008 08:08 AM
bearing with squeeling noise ghyslain Washer Repair 1 08-04-2008 02:17 AM
Frigidaire, loud squeeling, burning smell DEANO Dryer Repair 0 01-23-2008 09:57 AM
