| » Roper Gas Dryer not heating |
Model Number: RGX5635EQ3 Brand: Roper Age: 5 - 10 years
I was linked to this site thru another with part of the answer I was looking for. This one so far is much more help.
The dryer does not heat. The element does not glow either. I checked the continuity of the flame sensor and it is good. Am I to assume then that the heating element is bad? Or could there be another issue? Found answer in another post. The thermal fuse is bad. i will replace along with the cycling thermostat and see what happens. Thanks Last edited by Brian K : 01-03-2008 at 09:32 PM. Reason: Found more info. |
Post the results, please.
__________________
Professional appliance repair in Los Angeles, California. |
I'm glad you were able to fix it.
__________________
| Display Modes | |
| roper dryer with no heat | aaronii | Dryer Repair | 2 | 04-18-2008 07:33 AM |
| roper dryer repair | thecyclo | Dryer Repair | 7 | 01-27-2008 03:06 PM |
| Roper Dryer timer and heating issue | Wing Commander | Dryer Repair | 1 | 11-21-2007 12:11 AM |
| Roper Dryer will not run | TERRY38108 | Dryer Repair | 1 | 11-07-2007 05:21 PM |
| Roper Dryer not working at all now | cpego123 | Dryer Repair | 2 | 09-19-2007 06:46 PM |
