Discuss
Roper Gas Dryer not heating
 in
Dryer Repair
I was linked to this site thru another with part of the answer I was looking for. This one so
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper Gas Dryer not heating
  #1 (permalink)
Old 01-03-2008, 08:23 PM
Brian K Brian K is offline
Junior Member
Brian K is on a distinguished road
Default Roper Gas Dryer not heating
Model Number: RGX5635EQ3   Brand: Roper   Age: 5 - 10 years
I was linked to this site thru another with part of the answer I was looking for. This one so far is much more help.
The dryer does not heat. The element does not glow either. I checked the continuity of the flame sensor and it is good. Am I to assume then that the heating element is bad? Or could there be another issue?
Found answer in another post. The thermal fuse is bad. i will replace along with the cycling thermostat and see what happens.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-04-2008, 03:11 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Post the results, please.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-12-2008, 08:20 PM
Junior Member
Default Fixed
That fixed it.
The wife is happy.
Thanks for the help. Great website.
Until next time.
  #4 (permalink)
Old 01-15-2008, 12:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper dryer with no heat aaronii Dryer Repair 2 04-18-2008 07:33 AM
roper dryer repair thecyclo Dryer Repair 7 01-27-2008 03:06 PM
Roper Dryer timer and heating issue Wing Commander Dryer Repair 1 11-21-2007 12:11 AM
Roper Dryer will not run TERRY38108 Dryer Repair 1 11-07-2007 05:21 PM
Roper Dryer not working at all now cpego123 Dryer Repair 2 09-19-2007 06:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
