Discuss
Gas Dryer won't light or heat up
 in
Dryer Repair
My stackable Maytag SG1000 won't light up. I have good continuity of 76ohms across the igniter. I have perfect continuity
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer won't light or heat up
  #1 (permalink)
Old 01-12-2012, 12:55 PM
Junior Member
jimtowndave is on a distinguished road
Default Gas Dryer won't light or heat up
Model Number: SG 1000   Brand: Maytag   Age: More than 10 years
My stackable Maytag SG1000 won't light up. I have good continuity of 76ohms across the igniter. I have perfect continuity across the flame sensor. So what would prevent the igniter from getting power? If I understand correctly the coils would only be the problem if both the igniter and/or the flame sensor were functional and yet gas was still not flowing. Thanks.
Related Models
Hoover SG001---
Hoover SG005---
Hoover SG005001
Hoover SG007001
Maytag SG1000 STACKED LAUNDRY- GAS
Maytag SG1000T Stacked Laundry - Gas
Hardwick SG1616A49R RANGE- F/S STD GAS
Hardwick SG1616W49R RANGE- F/S STD GAS
Hardwick SG1616Y49R RANGE- F/S STD GAS
Amana SG19SL REF - SXS/I&W
Amana SG19SW REF - SXS/I&W
Amana SG22MBG REF - SXS/I&W
Amana SG22MBL REF - SXS/I&W
Amana SG22MBW REF - SXS/I&W
Amana SG521SBL REF - SXS/I&W
Amana SG521SBW REF - SXS/I&W
Amana SG521SW REF - SXS/I&W
Maytag SG7800 STACKED LAUNDRY- GAS
Hoover SG901---
Hoover SG903---
Hoover SG905---
Hoover SG907---
Hoover SG913---
Hoover SG915---
Hoover SG919---
Hoover SG921001
Hoover SG925
Hardwick SG9612W79RO RANGE- F/S STD GAS
Hardwick SG9617A429R RANGE- F/S STD GAS
Hardwick SG9617W429R RANGE- F/S STD GAS
Maytag SG9900 STACKED LAUNDRY- GAS
Thermador SGC304R
Thermador SGC304RB STEEL BURNER GAS COOKTOPS
Thermador SGC304RS STEEL BURNER GAS COOKTOPS
Roper SGC355XW0 Range (gas)*
Roper SGC355XW1 Range (gas)*
Roper SGC355XX2 Range (gas)*
Roper SGC355XX3 Range (gas)*
Thermador SGC365RB GAS COOKTOP
Thermador SGC365RS GAS COOKTOP
Thermador SGC365RW GAS COOKTOP
Thermador SGC456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RB SN 9803
Thermador SGC456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RS SN 9803
Thermador SGC456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RW SN 9803
Thermador SGCS304RB STEEL BURNER GAS COOKTOPS
Thermador SGCS304RS STEEL BURNER GAS COOKTOPS
Thermador SGCS304RW STEEL BURNER GAS COOKTOPS
Thermador SGCS365RB GAS COOKTOP
Thermador SGCS365RS GAS COOKTOP
Thermador SGCS365RW GAS COOKTOP
Thermador SGCS456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RB SN 9803
Thermador SGCS456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RS SN 9803
Thermador SGCS456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RW SN 9803
Thermador SGCV36 COOKTOP
Thermador SGCV3601 COOKTOP
Thermador SGCV36G01 COOKTOP
Thermador SGCV36G02 COOKTOP
Amana SGD22TL REF - SXS/I&W
Amana SGD22TW REF - SXS/I&W
Amana SGD26VL REF - SXS/I&W
Amana SGD26VW REF - SXS/I&W
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
  #2 (permalink)
Old 01-12-2012, 07:14 PM
Junior Member
Rocguy is on a distinguished road
Default
So does the ignitor ever glow at all? The more info you can provide, the better help you can get.
  #3 (permalink)
Old 01-12-2012, 09:04 PM
Junior Member
Default
Yeah, sorry I guess I didn't explain that. The dryer starts up with no errors and the drum spins. The igniter does not light up. I actually tried using a torch (maybe not so smart) to heat up the sensor to see if it would open the gas valve but gas never flowed. I talked to one guy that suggested testing for amperage to the igniter, if it's under 3.5 then it's not enough to trigger? I dunno.
  #4 (permalink)
Old 01-12-2012, 10:32 PM
Junior Member
Default
Yeah, I would put that torch away personally. Here are a couple of links that can help you troubleshoot it. If the ignitor never glows in the first place, I would highly suspect it.
http://forum.appliancepartspros.com/...ly-14/#more-14
How To Check Dryer Parts For Continuity
  #5 (permalink)
Old 01-18-2012, 09:24 PM
Junior Member
Default
Yeah, not much help there. Been through the continuity check for all these, like I said above. Seems that there would be an obvious place to check before igniter or flame sensor. Maybe just replace coils and hope it works? Frustrating.
  #6 (permalink)
Old 01-19-2012, 08:52 PM
Junior Member
Default
My dryer doesn't have an electronic board so it's fairly simple. About all I can suggest is searching for other posts with ignitor not glowing. You might be able to try that troubleshooting. Here is one example. Maybe one of the experts here will jump in to help. I hope.
Gas dryer no heat. Ignitor not glow.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer want heat up but a orange light on? SHANTA77 Dryer Repair 0 12-10-2010 07:57 PM
Pre Heat Light does not go out ba7fraley Oven Repair (including Ranges and Cooktops) 0 11-06-2010 08:22 AM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 05:54 PM
Dryer will run thrugh one heat cycle and not light again earl starkman Dryer Repair 0 09-14-2009 12:06 PM
How do I light dryer pilot light? Arleen Dryer Repair 1 03-20-2008 07:11 PM
