| » dryer not drying enough |
Model Number: lg6151xswo Brand: Whirlpool Age: 5 - 10 years
i have a whirpool that i replaced the high limit thermostat and it still isn't drying like it use too ? next to replacing the dryer where / what should i try next?
If it takes longer time to dry but there is warm inside the dryer then the problem is a clogged vent outside the dryer.
Disconnect the vent hose from the dryer and run a couple loads. If you see better time, then the vent has to be cleaned. - Here are the break down diagrams for the Whirlpool dryer Model LG6151XSW0 Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
There is a vent inside the wall and not only the vent hose.
This vent causing the air flow restriction more often. That's why I recommended to disconnect the hose and run a couple of loads without the hose. Gene.
__________________
| Display Modes | |
| Dryer not drying | mariebw | Dryer Repair | 3 | 12-30-2007 05:39 PM |
| Maytag dryer drying slowly | stodtmeister | Dryer Repair | 3 | 12-12-2007 06:12 PM |
| Dryer not drying | sue1759 | Dryer Repair | 5 | 11-02-2007 06:09 PM |
| Top of Dryer hot but clothes not drying | sween | Dryer Repair | 4 | 10-27-2007 01:29 PM |
| Gas Dryer not drying during run cycles | GMP | Dryer Repair | 1 | 09-28-2007 08:42 AM |
