My Kenmore Elite He3 model 110.84836201 dryer will not stop running unless the door is opened. The moisture sensor seems to be working -- Status "wet' light shows on the panel. If opened and closed, dryer will run even if a setting is not chosen (without heat). If a setting is pressed and start key is pressed (after the door is closed), the dryer will heat as expected. However, the dryer will continue to run when the cycle is complete (timer runs out). Can you help me define the problem?
