Discuss
Dryer running hot
 in
Dryer Repair
I recently replaced the thermal fuse and high limit thermostat. After the replacement, the dryer was running very hot. My
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer running hot
  #1 (permalink)
Old 07-09-2009, 07:27 PM
Junior Member
Rayb32 is on a distinguished road
Default Dryer running hot
Model Number: PYE2300AYW   Brand: Maytag   Age: 5 - 10 years
I recently replaced the thermal fuse and high limit thermostat. After the replacement, the dryer was running very hot. My new thermal fuse quit working. Today I replaced both again along with the thermostat (31001088) but it is running very hot in all modes. If I don't repair this, I expect the thermal fuse to go out again soon. What is my next step?
Ads By Google
Related Models
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
  #2 (permalink)
Old 07-09-2009, 07:35 PM
Senior Member
applianceman is on a distinguished road
Default
The most likely problem is an airflow problem such as the vent is stopped up or the blower is not working.
On Maytag it is very common for the blower to strip out and not move much air. Most of the time when this happens it will be very noisy. Clothes Dryer Repair Guide
  #3 (permalink)
Old 07-12-2009, 06:49 AM
Junior Member
Default
Thank you. I am not experiencing any excessive noise and I am getting plenty of exhaust at the outside vent. The dryer is very hot on all modes, even air fluff. Any other suggestions? Thanks again
  #4 (permalink)
Old 07-12-2009, 04:13 PM
Senior Member
Default
If it is hot on air fluff the heating element may be grounded out causing it to heat constantly possibly even on air-fluff. To check this disconnect power, and then unplug the wires going to the element. Then using an ohmmeter check to see if there is continuity between the terminals and the metal heater-can. If so the element is bad. If you do not have an ohmmeter sometimes you can visually see the heater coils touching the heater-can. Let us know what you find.
  #5 (permalink)
Old 07-12-2009, 07:32 PM
Junior Member
Default
Thank you, the element did ohm. I was able to place the coils back into place. At first test on fluff the heat did not come on. I think we are on track now. Will let you know if not. Thanks again.
  #6 (permalink)
Old 07-12-2009, 07:58 PM
Senior Member
Default
I recommend replacing the element but as long as it is working you might be ok. The worst thing that would happen is that it will shorten the life of the element but if I were working on it I would replace the element.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't keep running poetkinsle Dryer Repair 0 11-21-2009 01:09 PM
Dryer won't keep running thomwes2 Dryer Repair 2 11-18-2009 04:56 PM
Dryer not running pwrply2 Dryer Repair 1 04-17-2008 06:09 AM
Dryer won't keep running mnovara Dryer Repair 2 02-21-2008 05:50 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
