Discuss
Dryer will not heat up
 in
Dryer Repair
Hi, My Kenmore dryer will not heat up. The dryer works great otherwise. Can you help me with this problem?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not heat up
  #1 (permalink)
Old 07-09-2009, 08:32 AM
Junior Member
Steve T is on a distinguished road
Default Dryer will not heat up
Model Number: 11063032102   Brand: Kenmore   Age: 5 - 10 years
Thanks,
Related Models
Kenmore 11063032102 ELECTRIC DRYER
Kenmore 11063034100 ELECTRIC DRYER
Kenmore 11063034101 ELECTRIC DRYER
Kenmore 11063034102 ELECTRIC DRYER
Kenmore 11063036100 ELECTRIC DRYER
Kenmore 11063036101 ELECTRIC DRYER
Kenmore 11063036102 ELECTRIC DRYER
Kenmore 11063042100 ELECTRIC DRYER
Kenmore 11063042101 DRYER
Kenmore 11063042102 ELECTRIC DRYER
Kenmore 1106304400 KENMORE AUTOMATIC WASHER
Kenmore 1106304401 KENMORE AUTOMATIC WASHER
Kenmore 1106304402 KENMORE AUTOMATIC WASHER
Kenmore 1106304403 KENMORE AUTOMATIC WASHER
Kenmore 1106304450 KENMORE AUTOMATIC WASHER
Kenmore 1106304451 KENMORE AUTOMATIC WASHER
Kenmore 1106304452 KENMORE AUTOMATIC WASHER
Kenmore 1106304453 KENMORE AUTOMATIC WASHER
Kenmore 1106304500 KENMORE AUTOMATIC WASHER
Kenmore 1106304501 KENMORE AUTOMATIC WASHER
Kenmore 1106304502 KENMORE AUTOMATIC WASHER
Kenmore 1106304503 KENMORE AUTOMATIC WASHER
Kenmore 1106304550 KENMORE AUTOMATIC WASHER
Kenmore 1106304551 KENMORE AUTOMATIC WASHER
Kenmore 1106304552 KENMORE AUTOMATIC WASHER
Kenmore 1106304553 KENMORE AUTOMATIC WASHER
Kenmore 1106304600 KENMORE AUTOMATIC WASHER
Kenmore 1106304601 KENMORE AUTOMATIC WASHER
Kenmore 1106304602 KENMORE AUTOMATIC WASHER
Kenmore 1106304603 KENMORE AUTOMATIC WASHER
Kenmore 1106304604 KENMORE AUTOMATIC WASHER
Kenmore 1106304605 KENMORE AUTOMATIC WASHER
Kenmore 11063046100 ELECTRIC DRYER
Kenmore 11063046101 DRYER
Kenmore 11063046102 ELECTRIC DRYER
Kenmore 1106304650 KENMORE AUTOMATIC WASHER
Kenmore 1106304651 KENMORE AUTOMATIC WASHER
Kenmore 1106304652 KENMORE AUTOMATIC WASHER
Kenmore 1106304653 KENMORE AUTOMATIC WASHER
Kenmore 1106304654 KENMORE AUTOMATIC WASHER
Kenmore 1106304655 KENMORE AUTOMATIC WASHER
Kenmore 1106304700 KENMORE AUTOMATIC WASHER
Kenmore 1106304701 KENMORE AUTOMATIC WASHER
Kenmore 1106304702 KENMORE AUTOMATIC WASHER
Kenmore 1106304703 KENMORE AUTOMATIC WASHERS
Kenmore 1106304704 KENMORE AUTOMATIC WASHERS
Kenmore 1106304710 KENMORE AUTOMATIC WASHERS
Kenmore 1106304711 KENMORE AUTOMATIC WASHERS
Kenmore 1106304750 KENMORE AUTOMATIC WASHER
Kenmore 1106304751 KENMORE AUTOMATIC WASHER
Kenmore 1106304752 KENMORE AUTOMATIC WASHER
Kenmore 1106304753 KENMORE AUTOMATIC WASHERS
Kenmore 1106304754 KENMORE AUTOMATIC WASHERS
Kenmore 1106304760 KENMORE AUTOMATIC WASHERS
Kenmore 1106304761 KENMORE AUTOMATIC WASHERS
Kenmore 1106304800 MACHINE SUB-ASSEMBLY
Kenmore 1106304801 KENMORE AUTOMATIC WASHER
Kenmore 1106304802 KENMORE AUTOMATIC WASHER
Kenmore 1106304803 KENMORE AUTOMATIC WASHERS
Kenmore 1106304804 KENMORE AUTOMATIC WASHERS
Kenmore 1106304805 KENMORE AUTOMATIC WASHERS
Kenmore 1106304806 KENMORE AUTOMATIC WASHERS
Kenmore 1106304807 KENMORE AUTOMATIC WASHER
Kenmore 1106304850 MACHINE SUB-ASSEMBLY
Kenmore 1106304851 KENMORE AUTOMATIC WASHER
Kenmore 1106304852 KENMORE AUTOMATIC WASHER
Kenmore 1106304853 KENMORE AUTOMATIC WASHERS
Kenmore 1106304854 KENMORE AUTOMATIC WASHERS
Kenmore 1106304855 KENMORE AUTOMATIC WASHERS
Kenmore 1106304856 KENMORE AUTOMATIC WASHERS
Kenmore 1106304857 KENMORE AUTOMATIC WASHER
Kenmore 11063052100 DRYER
Kenmore 11063052101 DRYER
Kenmore 11063052102 ELECTRIC DRYER
Kenmore 1106305400 KENMORE AUTOMATIC WASHER
Kenmore 1106305401 KENMORE AUTOMATIC WASHER
Kenmore 1106305402 KENMORE AUTOMATIC WASHER
Kenmore 1106305403 KENMORE AUTOMATIC WASHER
Kenmore 1106305451 KENMORE AUTOMATIC WASHER
Kenmore 1106305452 KENMORE AUTOMATIC WASHER
Kenmore 1106305453 KENMORE AUTOMATIC WASHER
Kenmore 1106305500 KENMORE AUTOMATIC WASHER
Kenmore 1106305501 KENMORE AUTOMATIC WASHER
Kenmore 1106305502 KENMORE AUTOMATIC WASHER
Kenmore 1106305503 KENMORE AUTOMATIC WASHER
Kenmore 1106305551 KENMORE AUTOMATIC WASHER
Kenmore 1106305552 KENMORE AUTOMATIC WASHER
Kenmore 1106305553 KENMORE AUTOMATIC WASHER
Kenmore 1106305600 KENMORE AUTOMATIC WASHER
Kenmore 1106305601 KENMORE AUTOMATIC WASHER
Kenmore 1106305602 KENMORE AUTOMATIC WASHER
Kenmore 1106305603 KENMORE AUTOMATIC WASHER
Kenmore 1106305604 KENMORE AUTOMATIC WASHER
Kenmore 1106305605 KENMORE AUTOMATIC WASHER
Kenmore 1106305650 KENMORE AUTOMATIC WASHER
Kenmore 1106305651 KENMORE AUTOMATIC WASHER
Kenmore 1106305652 KENMORE AUTOMATIC WASHER
Kenmore 1106305653 KENMORE AUTOMATIC WASHER
Kenmore 1106305654 KENMORE AUTOMATIC WASHER
Kenmore 1106305655 KENMORE AUTOMATIC WASHER
Kenmore 1106305700 KENMORE AUTOMATIC WASHER
Kenmore 1106305701 KENMORE AUTOMATIC WASHER
Kenmore 1106305702 KENMORE AUTOMATIC WASHER
Kenmore 1106305703 KENMORE AUTOMATIC WASHERS
Kenmore 1106305704 KENMORE AUTOMATIC WASHERS
Kenmore 1106305710 KENMORE AUTOMATIC WASHERS
Kenmore 1106305711 KENMORE AUTOMATIC WASHERS
Kenmore 1106305750 KENMORE AUTOMATIC WASHER
Kenmore 1106305751 KENMORE AUTOMATIC WASHER
Kenmore 1106305752 KENMORE AUTOMATIC WASHER
Kenmore 1106305753 KENMORE AUTOMATIC WASHERS
Kenmore 1106305754 KENMORE AUTOMATIC WASHERS
Kenmore 1106305760 KENMORE AUTOMATIC WASHERS
Kenmore 1106305761 KENMORE AUTOMATIC WASHERS
Kenmore 1106305800 MACHINE SUB-ASSEMBLY
Kenmore 1106305801 KENMORE AUTOMATIC WASHER
Kenmore 1106305802 KENMORE AUTOMATIC WASHER
Kenmore 1106305803 KENMORE AUTOMATIC WASHERS
Kenmore 1106305804 KENMORE AUTOMATIC WASHERS
Kenmore 1106305805 KENMORE AUTOMATIC WASHERS
  #2 (permalink)
Old 07-09-2009, 04:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Steve,
The first thing I would do is check if there is 240 VAC to the dryer. The heater need 240 VAC while 120 VAC is good enough for the motor and the timer.
If there is nothing wrong then perform the troubleshooting as described in the Service manual.
Post the results and we will help you with the correct part numbers.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
