Hello:
I have a Roper Gas dryer that will not start. I have tested continuity on the start cycle relay, the thermal fuse, the timer motor, the thermal cutoff, both thermostats and the door switch. All items tested good. I get voltage (120) to the motor. This would lead me to believe that the motor has failed, but I want to make sure before I purchase a replacement part. Any responses are greatly appreciated.
