| » Whirlpool Dryer Not Heating |
Model Number: LE5700XSN0 Brand: Whirlpool Age: More than 10 years
Hello, My clothes dryer recently stopped heating. I've checked and reset the breaker.
*Blower Motor: Blowing Air *Heating Element: Has continuity, I also had it hooked up to a automotive jumper pack and it produced a small amount of (heat to the touch) due to the low voltage of the supply, and shows about 10 ohms on the meter. Thermal Fuse: Produced 0 ohms Thermostat: Has continuity, 0 ohms Timer Motor: I was unsure about the proper way to test this. Thermal Cutoff: When tested for continuity, there was NO continuity, and when checked for ohms, it showed as O.L. (Open Loop) on my meter. To me, I would *guess* the thermal cutoff, although I am a 27 year old guy with little appliance repair experience, other than when trying to avoid buying new when something can be fixed. Any help would be greatly appreciated, just let me know of any ideas any of you may have. Thank You, Corey Ads By Google Related Models |
Hi Corey,
You are on the right track. The thermal cut-off comes as a kit, including the high limit thermostat. You have to install both parts. - The thermal cut-off kit Part number: AP3094224 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LE5700XSW0 Residential Dryer | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thanks for the quick reply Gene. I see that you posted this as a 'Breakdown And Parts Diagram' for the LE5700XSW0 model. Is there any difference between this and my LE5700XSN0, or is it the same thing?
Thanks, Corey |
The only difference is the color.
__________________
No. That's why we check them for continuity.
__________________
You are welcome Corey. I'm glad it's up and running.
__________________
| Display Modes | |
| Whirlpool gas dryer not heating | Geokav | Dryer Repair | 0 | 02-26-2011 01:20 PM |
| whirlpool dryer not heating | biziswinning | Dryer Repair | 2 | 01-23-2011 07:11 AM |
| Whirlpool Dryer not heating up | mmatrull | Dryer Repair | 2 | 08-04-2010 02:00 PM |
| dryer Whirlpool not heating | rafaelgm | Refrigerator & Freezer Repair | 4 | 07-07-2010 04:51 PM |
| Whirlpool dryer not heating | distressed | Dryer Repair | 1 | 12-08-2008 11:26 AM |
