We have a whirlpool duet front load gas dryer model WGD9400SB0 and it has minimal heat (and now no heat) in the drum and blowing from the exhaust port to the rear. I have cleaned and removed the vent tube, cleaned all lint I can see thru the rear exhaust vent, run the dryer with the air flow venting into the laundry room. I no longer hear the click of the igniter. The dryer is 5 years old and has been in this same room for all 5 years. What is the most likely cause, please.
