Discuss
Timer not working and heat not working
 in
Dryer Repair
I recently had a situation where I put a load of clothes in the dryer and went to bed. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Timer not working and heat not working
  #1 (permalink)
Old 07-07-2009, 06:19 PM
JP2 JP2 is offline
Junior Member
JP2 is on a distinguished road
Default Timer not working and heat not working
Model Number: TEDS740PQ0   Brand: Estate   Age: 1 - 5 years
I recently had a situation where I put a load of clothes in the dryer and went to bed. I woke in the morning and my dryer was still running. The timer went bad and never rotated. At some point during the 7 hours the heat went out. I checked the ohms on the cycling thermostat (bottom left), thermal fuse (bottom left above cycling therm.) and the thermal cut-off (top right). previous post were unclear on which terminals to check for the fixed thermostat (bottom right). They say remove wires from one side (one side of what?).
Cycling thermostats red wires were 0.4 ohms, purple did not register. Thermal fuse was 0.4 ohms. Thermal cut-off was 0.4 ohms. Incoming voltage to unit was 240 +/- (before unplugging).
I'm trying to figure out what else I need to replace (in addition to the timer). Any help you guys can provide would be greatly appreciated.
Related Models
Whirlpool TEDS740PQ0 29"electric Dryer
Whirlpool TEDS740PQ1 29"electric Dryer
Whirlpool TEDS780JQ0
Whirlpool TEDS840JQ0
Whirlpool TEDS840JQ1
Whirlpool TEDS840JQ2
Whirlpool TEDS840JQ3 29"electric Dryer
Whirlpool TEDS840PQ0 29"electric Dryer
Whirlpool TEDS840PQ1 29"electric Dryer
Whirlpool TEDX340RW0 29" Electric Dryer
Whirlpool TEDX340RW1 29" Electric Dryer
Whirlpool TEDX340RW2 29" Electric Dryer
Whirlpool TEDX540RQ0 29" Electric Dryer
Whirlpool TEDX540RQ1 29" Electric Dryer
Whirlpool TEDX640EQ0
Whirlpool TEDX640EQ1
Whirlpool TEDX640EQ2
Whirlpool TEDX640JQ0
Whirlpool TEDX640JQ1
Whirlpool TEDX640JQ2 29"electric Dryer
Whirlpool TEDX640PQ0 29" Electric Dryer
Whirlpool TEDX640PQ1 29"electric Dryer
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FSA Tappan/range
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
Tappan TEF353AQF Tappan/electric Range
Tappan TEF353ASA Tappan/range
Tappan TEF353ASB Tappan/electric Range
Tappan TEF353ASC Tappan/electric Range
Tappan TEF353ASD Tappan/electric Range
Tappan TEF353ASE Tappan/range
Tappan TEF353ASF Tappan/electric Range
Tappan TEF353AUA Tappan/range
Tappan TEF353AUB Tappan/electric Range
Tappan TEF353AUC Tappan/electric Range
Tappan TEF353AUD Tappan/electric Range
Tappan TEF353AUE Tappan/range
  #2 (permalink)
Old 07-09-2009, 07:35 AM
JP2 JP2 is offline
Junior Member
Default
nevermind. figured it out on my own. for better service/help go to fixya.com
  #3 (permalink)
Old 07-09-2009, 04:19 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Sorry for the delay.
Most likely the problem is a bad timer. Remove the wires from the timer terminals BK & BU and check for continuity between these terminals while the timer is in "on" position (any cycle). If there is no continuity then the timer is the culprit.
Here is the the Tech sheet.
- The timer Part number: AP3131541
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL TEDS740PQ0 | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer not working? Kennick Dishwasher Repair 0 04-04-2009 05:27 PM
Electric dryer: will not heat and the timer quit working BC1988 Dryer Repair 2 01-02-2009 06:02 PM
Timer Not Working TVGALHH Microwave Repair 1 09-23-2008 01:37 PM
Gas dryer won't heat and timer not working mark55 Dryer Repair 3 12-30-2007 07:46 PM
Dryer doesnt heat but runs, timer isnt working either bridget Dryer Repair 0 11-03-2007 12:37 PM
