Discuss
Whirlpool electric dryer no LOW heat
 in
Dryer Repair
Sorry for the long post, I can usually figure this stuff out, but this one has me stumped. It is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool electric dryer no LOW heat
  #1 (permalink)
Old 07-07-2009, 02:30 PM
Junior Member
articcatbill is on a distinguished road
Default Whirlpool electric dryer no LOW heat
Model Number: LER5620KQ1   Brand: Whirlpool   Age: 5 - 10 years
It is a Whirlpool Dryer, LER5620KQ1, when set for low-heat we get no heat. The heating element does not come on at all. All the other cycles work fine, the automatic dry on high heat and the timed dry on high heat. This model does not have the timed dry on low heat.
From reading this forum I learned that on low heat a heating element on the dryer cycling thermostat boosts the temp by 20 degrees on the thermostat which causes the heat to be basically 20 degrees cooler. So I checked the voltage to that element and sure enough got 120V when set for low heat. Everything seemed to test out fine. Thinking that there was probably an issue with the thermostat and the heating on it I replaced it, as well as the high limit thermostat and thermal cut-off on the dryer heating element.
Well no luck, it still behaves as before, which I guess in my gut I expected since everything tested out OK (with multimeter) before I replaced it. I guess I was just tired of trouble shooting. I tried jumpering the drying cycling thermostat still no low heat.
So to wrap-up when set for low-heat we get no heat. It is sending voltage to the heating element on the dryer cycling thermostat when set for low-heat. Replaced the dryer cycling thermostat as well as the high limit thermostat and thermal cut-off. Heating element works fine on high-heat settings. Any help would be appreciated, thanks.
Ads By Google
Related Models
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
  #2 (permalink)
Old 07-07-2009, 04:43 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Most probable suspect is the timer AP3131541 You can remove the cover of the timer and confirm burnt contacts, or check the contacts externally in the low heat setting.
__________________
  #3 (permalink)
Old 07-08-2009, 05:20 PM
Junior Member
Default
Thanks for the reply richappy. I appreciate the feedback. I was trying to test the unit with my multimeter, but just wasn't sure exactly what the electrical diagram was showing me. Hadn't thought about opening the timer up and looking into it for burnt contacts, good idea, thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Electric Dryer No Heat MIKEK38E Dryer Repair 8 02-22-2010 05:56 AM
Whirlpool Dryer (electric) won't heat StephanieJoy Dryer Repair 1 09-24-2009 02:26 PM
Whirlpool Electric dryer only has hi heat asdf1855 Dryer Repair 3 05-26-2008 08:34 PM
Whirlpool electric dryer won't heat pilzperson Dryer Repair 0 04-03-2008 01:46 PM
Whirlpool Electric Dryer--No Heat hnumrich Dryer Repair 0 02-05-2008 06:14 AM
