Discuss
Whirlpool - Problem is No Heat
 in
Dryer Repair
Dear Dryer Repair Folks, Here is the problem: 1. The motor, drum, light are all operable and it spins nicely
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool - Problem is No Heat
  #1 (permalink)
Old 07-06-2009, 08:36 AM
Junior Member
Joel Gordes is on a distinguished road
Default Whirlpool - Problem is No Heat
Model Number: LGR7646EQ1   Brand: Whirlpool   Age: 5 - 10 years
2. The heat does not come on and I do not hear any noise of ignition
3) I had a flame sensor (AP2910747) I had to replace about 7 years ago and it has worked fine since then but maybe it has failed again
4) I would guess it might also be a thermal fuse or loose wire somewhere
5) What sequence should I use to test components to isolate the problem?
Any help is greatly appreciated.
Best,
Joel Gordes
Related Models
Whirlpool LGR7646EQ1 DRYERS
Whirlpool LGR7646EQ2 GAS DRYER
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
Whirlpool LGR7646EZ3 GAS DRYER
Whirlpool LGR7646JQ0 GAS DRYER
Whirlpool LGR7646JQ1 RESIDENTIAL DRYER
Whirlpool LGR7646JT0 GAS DRYER
Whirlpool LGR7646JT1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ0 RESIDENTIAL DRYER
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" GAS DRYER
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"GAS DRYER
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0 GAS DRYER
Whirlpool LGR8857EQ1 DRYERS
Whirlpool LGR8857EQ2 GAS DRYER
Whirlpool LGR8857EQ3 GAS DRYER
Whirlpool LGR8857EZ0 GAS DRYER
Whirlpool LGR8857EZ1 DRYERS
Whirlpool LGR8857EZ2 GAS DRYER
Whirlpool LGR8857EZ3 GAS DRYER
Whirlpool LGR8858DQ0 GAS DRYER
Whirlpool LGR8858DQ1 GAS DRYER
Whirlpool LGR8858DZ0 GAS DRYER
Whirlpool LGR8858DZ1 GAS DRYER
Whirlpool LGR8858EQ0 GAS DRYER
Whirlpool LGR8858EQ1 DRYERS
Whirlpool LGR8858EQ2 GAS DRYER
Whirlpool LGR8858EQ3 GAS DRYER
Whirlpool LGR8858EZ0 GAS DRYER
Whirlpool LGR8858EZ1 DRYERS
Whirlpool LGR8858EZ2 GAS DRYER
Whirlpool LGR8858EZ3 GAS DRYER
Amana LGS10AW WASHER-TOP LOADING
Amana LGS19AW DRYER- GAS
Amana LGS33AW DRYER- GAS
Amana LGS34AW WASHER-TOP LOADING
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AQ0 Residential Dryer
Whirlpool LGT5434AW0 Residential Dryer
Whirlpool LGT5436AW0 Residential Dryer
Whirlpool LGT5624BN0 GAS DRYER
Whirlpool LGT5624BN1 GAS DRYER
Whirlpool LGT5624BN2 GAS DRYER
Whirlpool LGT5624BQ0 GAS DRYER
Whirlpool LGT5624BQ1 GAS DRYER
Whirlpool LGT5624BQ2 GAS DRYER
Whirlpool LGT5624BW0 GAS DRYER
Whirlpool LGT5624BW1 GAS DRYER
Whirlpool LGT5624BW2 GAS DRYER
Whirlpool LGT5624DQ0 GAS DRYER
Whirlpool LGT5624DQ1 GAS DRYER
Whirlpool LGT6634AN1 DRYER
Whirlpool LGT6634AN2 GAS DRYER
Whirlpool LGT6634AQ0 GAS DRYER
Whirlpool LGT6634AQ1 GAS DRYER
Whirlpool LGT6634AQ2 GAS DRYER
Whirlpool LGT6634AW0 Residential Dryer
Whirlpool LGT6634AW1 DRYER
Whirlpool LGT6634AW2 GAS DRYER
Whirlpool LGT6634DQ0 GAS DRYER
Whirlpool LGT6634DQ1 GAS DRYER
Whirlpool LGT6634DZ0 GAS DRYER
Whirlpool LGT6634DZ1 GAS DRYER
Whirlpool LGT6638AN1 GAS DRYER
Whirlpool LGT6638AN2 GAS DRYER
Whirlpool LGT6638AQ2 GAS DRYER
Whirlpool LGT6638AW0 Residential Dryer
Whirlpool LGT6638AW1 GAS DRYER
Whirlpool LGT6638AW2 GAS DRYER
Whirlpool LGT6638DQ0 GAS DRYER
Whirlpool LGT6638DQ1 GAS DRYER
Whirlpool LGT6638DZ0 GAS DRYER
Whirlpool LGT6638DZ1 GAS DRYER
Whirlpool LGT7646AQ0 Residential Dryer
Whirlpool LGT7646AQ2 GAS DRYER
Whirlpool LGT7646AW0 Residential Dryer
Whirlpool LGT7646AZ2 GAS DRYER
Whirlpool LGT7646DQ0 GAS DRYER
Whirlpool LGT7646DQ1 GAS DRYER
Whirlpool LGT7646DZ0 GAS DRYER
Whirlpool LGT7646DZ1 GAS DRYER
Whirlpool LGT7646EQ0 GAS DRYER
Whirlpool LGT7646EQ1 DRYERS
Whirlpool LGT7646EQ2 GAS DRYER
Whirlpool LGT7646EQ3 GAS DRYER
Whirlpool LGT7646EZ0 GAS DRYER
Whirlpool LGT7646EZ1 DRYERS
  #2 (permalink)
Old 07-06-2009, 09:05 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Look to see if the ignitor glows when you start the dryer. If it does, does it cycle on and off?
  #3 (permalink)
Old 07-06-2009, 09:21 AM
Junior Member
Default Whirlpool - Problem is no heat
Quote:
OK, will do, but how is the best way to see the ignitor. Maybe I missed this in the parts list but I did not see it listed and I was looking for it too. Do I have to take off the whole front to see it is the question??? If not where do I look for it?
  #4 (permalink)
Old 07-06-2009, 10:28 AM
Senior Expert
APP Volunteer
Default
A lot of gas dryers have a small access panel at the front/bottom, that can be removed, usually by prying it away, to expose the coils, burner, ignitor and flame (radiant) sensor. If yours does not, you can still see a glow coming from beneath the dryer in the front, if you can darken the room, while the dryer is running. Sometimes you can also see from a small hole in the back of the machine.
  #5 (permalink)
Old 07-06-2009, 11:01 AM
Junior Member
Default
Hi Magician59,
OK, I will try this tonight once it gets dark enough and report back to you on it as I don't think I can darken the area around it enough during daylight hours. Thanks for your help on this.
Best,
Joel Gordes
  #6 (permalink)
Old 07-06-2009, 06:24 PM
Junior Member
Default Evening Test of Dryer Igniter
OK, Magician59, Here is where we're at:
1) I opened the top of the dryer and I tried to see a glow when we turned it on. Motor ran fine, drum turned but I saw no glow.
2) Disconnected the drive belt and pulled out the drum. reattached door switch connect for continuity. Started it and the motor ran. Still no glow.
3) Unscrewed the igniter from the holder, played with the connector and tried power again---still no glow.
4) Disconnected the igniter and it was not visibly broken but was sparkling carbon but less so towards it tips and on the back side. Measured across it's connector leads showing 63 ohms.
5) Where next?? Took a photo of it but too large to upload without dumbing it down a bit.
Best,
Joel Gordes
  #7 (permalink)
Old 07-06-2009, 09:12 PM
Senior Expert
APP Volunteer
Default
Since you have the ignitor disconnected, you may want to check for voltage at its connectors. You'll need to temporarily close the door switch and protect the terminals from accidentally grounding against metal. If you get voltage at the ignitor connection, you may have a burnt out ignitor. Try not to touch the carbon element, as you can foul it, similar to handling the modern headlamps of our cars.
If you replace it, you might also want to replace the coils, while you're at it.
  #8 (permalink)
Old 07-07-2009, 07:24 AM
Junior Member
Default
Great idea on the test of the hot side. Duh, why didn't I think of that?? Will get to it this evening and let you know the results.
  #9 (permalink)
Old 07-07-2009, 04:37 PM
Junior Member
Default
Hi Magician59,
OK, I set up my multimeter on AC and placed the probes into the socket from which I removed the dryer ignitor. Then I turned on main switch and the motor ran BUT I saw no real rise in output on the meter. Did I do this correctly? Would have expected some output but got barely percptible figures that varied a bit and that was all.
Best,
Joel Gordes
  #10 (permalink)
Old 07-09-2009, 08:27 AM
Junior Member
Default
Hi Magician59,
Did not get reply to my last post. Are you still with me on this. If I did it right, I got no voltage across the supply side that goes to the ignitor. Waht would be next step to trace this back?
Best,
Joel Gordes
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Questions on fixing Whirlpool gas dryer no heat problem yzhong Dryer Repair 1 06-05-2010 07:32 PM
Heat Problem fire100 Dryer Repair 2 10-27-2009 09:33 PM
high heat problem mm6018 Dryer Repair 3 07-17-2009 12:21 AM
dryer heat problem ribwholesalers Dryer Repair 1 07-09-2009 04:00 AM
dryer heat problem wtelwe Dryer Repair 1 02-11-2009 03:24 AM
