| » e ring p/n AP2042332 and heating coils |
Model Number: DDE9200BAC Brand: GE Age: More than 10 years
While removing the drum to replace the heating coils the e ring was bent pretty badly. It turns out the e ring is no longer made by GE. Is this something I can just get at a hardware store?
I am replacing the heating coils and am wondering if I have the unit torn apart this far (drum out) are there other parts that should also be replaced like the insulators? The parts look OK but they've seen alot of heat over the past 27 years. I replaced the drive belt last year so that is one item that is ok. Thanks. David Ads By Google Related Models |
I am assuming you are talking about the clip that you have to remove from the drum shaft to remove the drum. If so you no longer need it as long as you replace the bearing (part number WE3X75), which you probably need to anyways. As far as the insulators go just inspect them to see if they are burnt or cracked if not no need to replace them. Clothes Dryer Repair Guide
| Display Modes | |
| Balance Ring hitting Ring Tub and water on floor | mrwto | Washer Repair | 5 | 02-01-2010 07:42 AM |
| Replacing Ring Deadening sound ring part # 63134 | JOANBAPP | Washer Repair | 2 | 10-31-2009 06:56 PM |
| Thermador burner outer ring not heating up | DavidTherm | Oven Repair (including Ranges and Cooktops) | 2 | 06-21-2009 11:55 AM |
| Amana heating coils are not getting hot. | sf46 | Dishwasher Repair | 2 | 04-12-2009 08:54 AM |
| heating coils glow red | stacy | Dryer Repair | 1 | 11-01-2007 04:03 AM |
