Discuss
Kenmore Elite Electric Dryer stops before clothes are dry in Mositure Sensing Mode
 in
Dryer Repair
Dryer stops and beeps before clothes are completely dry in moisture sensing mode. Also the same occurs sometimes in timed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Elite Electric Dryer stops before clothes are dry in Mositure Sensing Mode
  #1 (permalink)
Old 12-30-2011, 02:26 PM
Junior Member
jgkunowsky is on a distinguished road
Default Kenmore Elite Electric Dryer stops before clothes are dry in Mositure Sensing Mode
Model Number: 11060996990   Brand: Kenmore   Age: More than 10 years
Dryer stops and beeps before clothes are completely dry in moisture sensing mode. Also the same occurs sometimes in timed mode. In the past, replacing even heat control board (part# 3976609, 85446223, W10116564) has solved the problem. Replaced 85446223 control board with current replacement W10116564. Did not solve problem this time.
Inspected - cleaned all exhaust piping, blower housing, blower fan wheel and lint filter screen and tested for full flow. Removed -Inspected heater box. Heating element was scortched on distal end from wiring terminals. Installed new heating element 3387747, Thermostat and Hi-temp cut off kit 279769 and thermistor 8577274. When replacing the thermisitor , I noticed the original unit has a flat diagonal rod shaped element and the blower housing had a diamond shaped cut out to accommodate this sensor. Removed from blower housing, It was 0 ohm at room temp (closed).
The replacement thermistor had a circular molded collar around a bulb shaped element. The collar would not fit flush down in the diamond shaped blower housing cut out so I filed it off. Also the wiring connection terminals were wider so I filed them down to fit the control wire terminals. It was 11.5K ohms at room temp (70F) .
After replacing all of above, dryer would not start. Suspected new thermistor. Removed and tested again. It was 1 ohm (open) . Replaced with old thermisitor and dryer runs and heats.
Why did new thermistor blow?
Did I get the wrong part# or a bad replacement?
I am concerned that temperature control circuit is not functioning with the old thermistor continuously closed at 0 ohm.
What should I do / check next?
Related Models
Kenmore 11060996990 ELECTRIC DRYER
Kenmore 11060997990 ELECTRIC DRYER
Kenmore 1106101100 KENMORE WRINGER WASHER
Kenmore 1106101400 KENMORE WRINGER WASHER
Kenmore 1106101401 KENMORE WRINGER WASHER
Kenmore 1106101402 KENMORE WRINGER WASHER
Kenmore 1106102300 KENMORE WRINGER WASHER
Kenmore 1106102500 KENMORE WRINGER WASHER
Kenmore 1106102501 KENMORE WRINGER WASHER
Kenmore 1106102600 KENMORE WRINGER WASHER
Kenmore 1106102601 KENMORE WRINGER WASHER
Kenmore 1106102700 KENMORE WRINGER WASHER
Kenmore 1106102701 KENMORE WRINGER WASHER
Kenmore 1106102702 KENMORE WRINGER WASHER
Kenmore 1106102710 KENMORE WRINGER WASHER
Kenmore 1106102711 KENMORE WRINGER WASHER
Kenmore 1106102720 KENMORE WRINGER WASHER
Kenmore 1106102800 KENMORE WRINGER WASHER
Kenmore 1106102801 KENMORE WRINGER WASHER
Kenmore 1106102802 KENMORE WRINGER WASHER
Kenmore 1106102850 KENMORE WRINGER WASHER
Kenmore 1106103000 KENMORE SEMI-AUTOMATIC WASHER
Kenmore 1106104200 KENMORE AUTOMATIC WASHER
Kenmore 1106104300 KENMORE AUTOMATIC WASHER
Kenmore 1106104350 KENMORE AUTOMATIC WASHER
Kenmore 1106104500 KENMORE AUTOMATIC WASHERS
Kenmore 1106104510 KENMORE AUTOMATIC WASHER
Kenmore 1106104520 KENMORE AUTOMATIC WASHER
Kenmore 1106104550 KENMORE AUTOMATIC WASHERS
Kenmore 1106104560 KENMORE AUTOMATIC WASHER
Kenmore 1106104570 KENMORE AUTOMATIC WASHER
Kenmore 1106104700 KENMORE AUTOMATIC WASHERS
Kenmore 1106104750 KENMORE AUTOMATIC WASHERS
Kenmore 1106104810 KENMORE AUTOMATIC WASHER
Kenmore 1106104860 KENMORE AUTOMATIC WASHER
Kenmore 1106105300 KENMORE AUTOMATIC WASHER
Kenmore 1106105350 KENMORE AUTOMATIC WASHER
Kenmore 1106105500 KENMORE AUTOMATIC WASHERS
Kenmore 1106105510 KENMORE AUTOMATIC WASHER
Kenmore 1106105520 KENMORE AUTOMATIC WASHER
Kenmore 1106105550 KENMORE AUTOMATIC WASHERS
Kenmore 1106105560 KENMORE AUTOMATIC WASHER
Kenmore 1106105570 KENMORE AUTOMATIC WASHER
Kenmore 1106105700 KENMORE AUTOMATIC WASHERS
Kenmore 1106105750 KENMORE AUTOMATIC WASHERS
Kenmore 1106105810 KENMORE AUTOMATIC WASHER
Kenmore 1106105860 KENMORE AUTOMATIC WASHER
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
Kenmore 1106107800 KENMORE GAS DRYER
Kenmore 1106107801 KENMORE GAS DRYER
Kenmore 1106107803 KENMORE GAS DRYER
Kenmore 11061082000 DRYER
Kenmore 1106108400 KENMORE ELECTRIC DRYER
Kenmore 11061084000 DRYER
Kenmore 1106108401 KENMORE ELECTRIC DRYER
Kenmore 1106108500 KENMORE ELECTRIC DRYER
Kenmore 1106108501 KENMORE ELECTRIC DRYER
Kenmore 11061086000 DRYER
Kenmore 1106108700 KENMORE ELECTRIC DRYER
Kenmore 1106108701 KENMORE ELECTRIC DRYER
Kenmore 1106108710 KENMORE ELECTRIC DRYER
Kenmore 1106108800 KENMORE ELECTRIC DRYER
Kenmore 1106108801 KENMORE ELECTRIC DRYER
Kenmore 1106108802 KENMORE ELECTRIC DRYER
Kenmore 1106109100 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109101 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109102 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109105 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 11061092000 DRYER
Kenmore 1106109500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109501 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109504 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109505 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109800 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109801 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109802 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109803 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109804 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109805 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109807 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109808 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109809 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106109810 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1106110100 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110101 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110102 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110105 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110500 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110501 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110502 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110504 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110505 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110800 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110801 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110802 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110803 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110804 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110805 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110807 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110808 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110809 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106110810 KENMORE ELECTRIC COMBINATION WASHER-DRYER
Kenmore 1106112600 KENMORE WRINGER WASHER
Kenmore 1106114200 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114210 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114220 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114221 KENMORE COIN-OPERATED AUTOMATIC WASHER
Kenmore 1106114222 KENMORE AUTOMATIC WASHER
Kenmore 1106114230 KENMORE AUTOMATIC WASHERS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stops at Sensing Mode Tom Whitlow Dishwasher Repair 2 07-17-2011 09:08 PM
kenmore elite electric dryer overheating at times cindykkk Dryer Repair 1 02-04-2011 10:22 AM
Kenmore Elite Electric Dryer thumbs10 Dryer Repair 2 10-01-2010 07:31 AM
Kenmore Elite dryer heats then stops toothfxr Dryer Repair 0 09-06-2009 08:12 AM
Kenmore Elite stuck sensing cunukster Dishwasher Repair 0 10-05-2008 11:54 AM
