| » Automatic Dry-Miser |
Model Number: LGR7646EQ3 Brand: Whirlpool Age: More than 10 years
When I use the setting to sense when clothes are and shut off. It doesnt sense that they are dry. It runs long after they're dry and evenually shuts off. Both the Dryer Cycling Thermostat and the High Limit Thermostat have continuity. What part needs to be replaced?
Before I replaced any parts I would check the dryer vent and blower housing to make sure there is no lint build up that needs to be cleaned out.
Here is a example of what the blower housing on the back of your dryer looks like. http://appliancejunk.com/forums/inde...a=view;pic=384
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
When I use the setting to sense when clothes are dry and shut off, it doesn't sense that they are dry. It runs long after they're dry and evenually shuts off. The timer barely moves to the point when they are dry. Eventually it shuts off when the timer has moved to the off position. Both the Dryer Cycling Thermostat and the High Limit Thermostat have continuity. I've replaced the High Limit Thermostat and that didn't solve the problem. Both dryer vent and and blower housing are clear. What should I check next and/or what part needs to be replaced
| Display Modes | |
| Whirlpool Gas Dryer. Heats but will not shut off if on auto dry miser setting | tornado26 | Dryer Repair | 5 | 01-01-2012 09:43 AM |
| whirlpool dryer wont start in dry miser mode | tequilla | Dryer Repair | 3 | 06-23-2008 07:03 PM |
| Automatic ON | tdaughton | Oven Repair (including Ranges and Cooktops) | 1 | 03-18-2008 04:16 PM |
| Heavy frost build-up in freezer with power miser | bps01 | Refrigerator & Freezer Repair | 2 | 12-19-2007 11:22 AM |
