Discuss
petmac
 in
Dryer Repair
The above is a washer & dryer, one unit stackable ( Laundry Center). It is Brand New. I just learned
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » petmac
  #1 (permalink)
Old 07-05-2009, 02:23 PM
Junior Member
petmac is on a distinguished road
Angry petmac
Model Number: glet1031fs2   Brand: Frigidaire   Age: Less than 1 year
The above is a washer & dryer, one unit stackable ( Laundry Center). It is Brand New. I just learned while installing it that the washer & dryer should not (Installation Instructions) be run at the same time because of the 3-wire 240 volt feed. The 120 volts needed for the washer is tapped off of the units 240 volt Neutral & Red Leg. I would like to connect the washer to a seperate 120 volt outlet and disconnect it from the 240 in the units terminal block, this way I can run the washer & dryer at the same time without any apmerage overload. All 2-unit stackables are wired this way. Is there any reason you would know of MECHANICALLY, that would prohibit using the above units, washer and dryer at the same time???
Related Models
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
Frigidaire GLFH21F8HBC FREEZER
Frigidaire GLFH21F8HBD FREEZER
Frigidaire GLFH21F8HBE FREEZER
Frigidaire GLFH21F8HWA FREEZER
Frigidaire GLFH21F8HWB FREEZER
Frigidaire GLFH21F8HWC FREEZER
Frigidaire GLFH21F8HWD FREEZER
Frigidaire GLFH21F8HWE FREEZER
Frigidaire GLFH21F8HWG FREEZER
Frigidaire GLFN1326GW0 FREEZER
Frigidaire GLFN1326GW1 FREEZER
Frigidaire GLFN1326GW2 FREEZER
Frigidaire GLFN1326GW3 FREEZER
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1467FW1 FREEZER
Frigidaire GLFU1467FW2 FREEZER
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU1767FW5 FREEZER
Frigidaire GLFU1767FW6 FREEZER
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLFU2067FW5 FREEZER
Frigidaire GLFU2067FW6 FREEZER
Frigidaire GLFU2067FW7 FREEZER
Frigidaire GLFU2067FW8 FREEZER
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC30S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSB Frigidaire/gas Cooktop
Frigidaire GLGC30S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S9ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBB Frigidaire/gas Cooktop
  #2 (permalink)
Old 07-07-2009, 01:12 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Petmac
I am going to ask you to confirm with Frigidaire that you cannot run the washer at the same time with the dryer. Here is some contact info.
http://www.frigidaire.com/customersupport
I looked at the operating instructions and I did not see any such prohibition. On the installation instructions it says not to have a washer and a dryer on the same circuit, which make sense for separate units but not for yours, so I am wondering if this is the language you saw that lead you to your conclusion about operating simultaneously.
Manuals are not always written correctly, and I am wondering if the sentence about not putting on the same circuit is just boilerplate and just got in there from some other manual, and does not apply to your model.
Anyway, that being said I would not advise you to tamper with the internal wiring. The first thing that will happen is that it will void your warranty. If Frigidaire confirms that you cannot use them simultaneous, then I would advise taking that advice.
Well, let us know what you find out, I think you will find that you can operate them together and that the info in the installation manual was referring to hooking up separate units to the same circuit.
__________________
  #3 (permalink)
Old 07-15-2009, 12:20 PM
Junior Member
Thumbs up
Quote:
Originally Posted by sidfink43 View Post
Hi Petmac
My research confirms the above. I can operate the washer & dryer at the same time. Thank You. petmac
  #4 (permalink)
Old 07-15-2009, 01:31 PM
Senior Expert
APP Volunteer
Default
Glad you checked it out and thanks for updating us.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
