Dryer will not start. Light inside does not come on. Timer motor runs. I have checked voltage to dryer side of input and get 220VAC. Door switch tests ok. What can I check next? Thanks
Looking at the wiring diagram if the thermal fuse is bad on this model the light will not work. Thermal fuse is #5 in the diagram and is mounted on the side of the heater. I would check it for continuity.
