Jim186
#1 Posted : Thursday, December 29, 2011 5:15:43 AM(UTC)
Jim186
Dryer will not start. Light inside does not come on. Timer motor runs. I have checked voltage to dryer side of input and get 220VAC. Door switch tests ok. What can I check next? Thanks
ApplianceJunk
#2 Posted : Thursday, December 29, 2011 6:21:41 AM(UTC)
ApplianceJunk
Looking at the wiring diagram if the thermal fuse is bad on this model the light will not work. Thermal fuse is #5 in the diagram and is mounted on the side of the heater. I would check it for continuity.
UserPostedImage
Jim186
#3 Posted : Friday, December 30, 2011 10:53:24 AM(UTC)
Jim186
Thanks, that's exactly what it was (thermal fuse). I found the schematic after posting and was able to determine problem. New fuse was $35 and I had to replace both even though only one was bad. New one has a lifetime warranty. Thanks for the post...
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
