The dryer has stopped heating. Once the dryer is started it runs through its cycle like normal just no heat. I have tested the unit on low, medium and high heat, and none of the work. I have tested the the coil elemant with an OHM meter and there is no break. What else could be the problem?
Have you tested the thermostats/thermal fuses? If not, check them out and let us know what you find out.
Good luck
