Discuss
Electric dryer will not start
 in
Dryer Repair
After about 10 minutes of drying the dryer stopped and never started again. I have checked the door switch, safety
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Electric dryer will not start
  #1 (permalink)
Old 07-03-2009, 02:59 PM
Junior Member
livergrrl is on a distinguished road
Default Electric dryer will not start
Model Number: DDE7500GBLWH   Brand: GE   Age: More than 10 years
After about 10 minutes of drying the dryer stopped and never started again. I have checked the door switch, safety switch and start button by continuity and shorting them. The timer runs and the end of cycle signal works. I have tested for 120v and 240v at the terminal block inside the dryer. The 3770 ohm resistor checks excat with the ohm meter. I set it on fluff which should eliminate the heating system and no luck. Is this a legitimate way to eliminate the heating system including the high limit, high drum outlet and low drum outlet switches? If it is the motor or motor start switch how should I test them? What else can it be? Any help is appreciated.
Ads By Google
Related Models
General Electric DDE7600RAL Electric dryer
General Electric DDE7606 ELECTRIC DRYER
General Electric DDE7606MAL Electric dryer
General Electric DDE7606MBL Electric dryer
General Electric DDE7606MCL Electric dryer
General Electric DDE7606MDL Electric dryer
General Electric DDE7608 ELECTRIC DRYER
General Electric DDE7608MAL Electric dryer
General Electric DDE7608MBL Electric dryer
General Electric DDE7608MCL Electric dryer
General Electric DDE7608MDL Electric dryer
General Electric DDE7900BBL Electric dryer
General Electric DDE7900GAL Electric dryer
General Electric DDE7900GBL Electric dryer
General Electric DDE7900GDL Electric dryer
General Electric DDE7900MAL Electric dryer
General Electric DDE7900MBL Electric dryer
General Electric DDE7900MCL Electric dryer
General Electric DDE7900MDL Electric dryer
General Electric DDE7900RAL ELECTRIC DRYER
General Electric DDE7900RALAA Electric dryer
General Electric DDE7900RALWW Electric dryer
General Electric DDE7900SAL Electric dryer
General Electric DDE7900SBLAA Electric dryer
General Electric DDE7900SBLWW Electric dryer
General Electric DDE7905SBLAA Electric dryer
General Electric DDE7905SBLWW Electric dryer
General Electric DDE7906LAL Electric dryer
General Electric DDE7906RAL Electric dryer
General Electric DDE7907RAL Electric dryer
General Electric DDE7909RAL Electric dryer
General Electric DDE8000MAL Electric dryer
General Electric DDE8000MBL Electric dryer
General Electric DDE8100DAL Electric dryer
General Electric DDE8100DBL GE DRYERS, ELECTRIC
General Electric DDE8107MAL Electric dryer
General Electric DDE8108VHL Electric dryer
General Electric DDE8108VJL GE DRYERS, ELECTRIC
General Electric DDE8109VML Electric dryer
General Electric DDE8200BAC Electric dryer
General Electric DDE8200DAL Electric dryer
General Electric DDE8200DBL GE DRYERS, ELECTRIC
General Electric DDE8200GAL Electric dryer
General Electric DDE8200GBL Electric dryer
General Electric DDE8200GDL Electric dryer
General Electric DDE8200RAM Electric dryer
General Electric DDE8200RBM Electric dryer
General Electric DDE8200RCM Electric dryer
General Electric DDE8200RFM Electric dryer
General Electric DDE8200SAMAA Electric dryer
General Electric DDE8200SAMWW Electric dryer
General Electric DDE8200SBMAA Electric dryer
General Electric DDE8200SBMWW Electric dryer
General Electric DDE8500RAM Electric dryer
General Electric DDE8500RBM Electric dryer
General Electric DDE8500RCM Electric dryer
General Electric DDE8500RFM Electric dryer
General Electric DDE8500SAMAA Electric dryer
General Electric DDE8500SAMWH Electric dryer
General Electric DDE8500SAMWW Electric dryer
General Electric DDE8500SBMAA Electric dryer
General Electric DDE8500SBMWH Electric dryer
General Electric DDE8500SBMWW Electric dryer
General Electric DDE8505SAMAA Electric dryer
General Electric DDE8505SAMWW Electric dryer
General Electric DDE8505SBMAA Electric dryer
General Electric DDE8505SBMWW Electric dryer
General Electric DDE8506MAL Electric dryer
General Electric DDE8506MBL Electric dryer
General Electric DDE8508MAL Electric dryer
General Electric DDE8508MBL Electric dryer
General Electric DDE8509RCM
General Electric DDE8509RCMAA Electric dryer
General Electric DDE8509RCMWW Electric dryer
General Electric DDE8509RFMAA Electric dryer
General Electric DDE8509RFMWW Electric dryer
General Electric DDE8509RMC ELECTRIC DRYER
General Electric DDE9200BAC Electric dryer
General Electric DDE9200DAL Electric dryer
General Electric DDE9200DBL GE DRYERS, ELECTRIC
General Electric DDE9200GAL Electric dryer
General Electric DDE9200GBL Electric dryer
General Electric DDE9200GDL Electric dryer
General Electric DDE9300LAL Electric dryer
General Electric DDE9300LBL Electric dryer
General Electric DDE9500MAL Electric dryer
General Electric DDE9500MBL Electric dryer
General Electric DDE9500RAM Electric dryer
General Electric DDE9500RCM Electric dryer
General Electric DDE9500RFM Electric dryer
General Electric DDE9600MAL Electric dryer
General Electric DDE9600MBL Electric dryer
General Electric DDE9600RAM Electric dryer
General Electric DDE9600RCM ELECTRIC DRYER
General Electric DDE9600RCMAA Electric dryer
General Electric DDE9600RCMWW Electric dryer
General Electric DDE9600RFMAA Electric dryer
General Electric DDE9600RFMWW Electric dryer
General Electric DDE9605SAMAA Electric dryer
General Electric DDE9605SAMWW Electric dryer
General Electric DDE9605SBMAA Electric dryer
General Electric DDE9605SBMWW Electric dryer
General Electric DDE960SSAMWW ELECTRIC DRYER
General Electric DDG4580GAL Gas dryer
General Electric DDG4580GCL Gas dryer
General Electric DDG4580GDL Gas dryer
General Electric DDG4580GEL Gas dryer
General Electric DDG5180 GAS DRYER
General Electric DDG5180MAL Gas dryer
General Electric DDG5180MBL Gas dryer
General Electric DDG5180MCL Gas dryer
General Electric DDG5180RAL GAS DRYER
General Electric DDG5180RALWW Gas dryer
General Electric DDG5180RBL BACKSPLASH DRYER PROGRAM
General Electric DDG5180RBLWW Gas dryer
General Electric DDG5180RCL
General Electric DDG5180RCLWW Gas dryer
General Electric DDG5180SBLAA Gas dryer
General Electric DDG5180SBLWW Gas dryer
General Electric DDG5189VSL Gas dryer
  #2 (permalink)
Old 07-05-2009, 07:29 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi
If you look at the exploded parts diagrams on this site you will see that you have thermal devices (thermostats, safety themostats ect) on both the heater coil housing and the blower cover. Have you checked all of these for continuity.
If they are all good, the problem is likely in your motor switch (but could be the motor itself in a machine this old).
Let us know what you find if you check all of those (or if you have already done so).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric dryer won't start WhittierM Dryer Repair 3 01-09-2010 10:58 AM
GE electric dryer won't start aqrose Dryer Repair 1 11-30-2009 08:31 PM
GE Electric Dryer won't start teachef Dryer Repair 2 10-03-2009 04:11 PM
GE electric dryer will not start qzymfl Dryer Repair 7 07-27-2009 06:21 PM
Electric dryer will not start kheinrich Dryer Repair 3 08-21-2008 09:22 AM
